11-12-2014 02:06 PM
I'm trying to put together an EEM based TCL script for a "call home" like feature (if a client's VPN router behind NAT is not reachable via VPN tunnel, the router would get the backdoor open from inside to netcat), all works except passing control chars (ctrl-C, ctrl-Z, up arrow, etc), I see the commands arrive at TCL via a socket properly encoded (regexe properly identified utf-8 or octet coding), however when passed to CLI using cli_exec or cli_write, not treated as controls.
The TCL opens a TCP socket to xinetd with NCAT without any TELNET negotiations
The absence of the controls is not a huge issue, more like "nice to have"
appreciate any feedback
11-12-2014 02:48 PM
Can you share your code? Control characters definitely work on a socket, but if you have to go through the CLI, you may have to use some tricks to pass them along. It would be useful to see what you have now.
11-12-2014 04:00 PM
Sure, the tcl script is attached. The way it works is a VPN router runs the script on EEM cron every 15 min. the script opens a socket to a jump server's xinetd on tcp 80, xinetd starts a shell wrapper around ncat (the one that comes with nmap). The launched instance of ncat starts listening on tcp 8001 - 8999 (the wrapper finds an available port for it from the given range, also collects the router's name and logs in a file). At this point an operator can telnet to let's say 8001 on the jumper box and get cli of the VPN router
11-12-2014 04:11 PM
So is Ctrl+C/Z coming through as binary from the socket? What other things are you trying to send? Are you trying to do a send command or something within config mode? If they are coming through in binary, you might try special casing them, and send the literal character using Ctrl+V+Ctrl+Z/C.
11-12-2014 04:59 PM
in the fconfigure tried -encoding binary, utf-8, no -encoding, does not seem to make any difference
had a temp regexe;
11-13-2014 08:28 AM
update:
the ctrl-Z (\001a) seem to work (even without ctrl-V prepended), although with a bit of decoded garbage: it goes to cli_write as C?C8^Z, the cli_read_drain returns:
call call-history-mib call-home cdp
cef chat-script class-map clock
cns config-register connect control-plane
crypto cwmp
testrtr01(config)# ^
% Invalid input detected at '^' marker.
testrtr01#
testrtr01#
Nov 13 10:53:28.449: %SYS-5-CONFIG_I: Configured from console by on vty0 (EEM:eemcat.tcl)
so, CLI takes the first C as the beginning of the command then evaluates ^Z and gets out of config mode
The ctrl-V (\u0016) is not working,
The ctrl-P (\u0010) or up arrow (\u001b[A) no working with ctrl-V (\u0016) pre pended or without:
with ctrl-V in front getting
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
without, no output
giving up on this
On the other note, is there a way to make cli_read* async, so it could read debug messages as they show up. If I put it in while loop, it will block the socket's fileevent (or is it even possible to have more than one vwait forever in tcl)?
11-13-2014 01:16 PM
I had kind of meant like special casing things in your callback, then doing:
cli_exec $cli1(fd) "Ctl+V+Ctl+Z"
Where those are the literal characters you typed into the text file. Make sense?
Unfortunately, no, cli_read is sync. I have requested this to be more of an async thing or at least something you can time out, but that has not been implemented.
11-14-2014 10:17 AM
nope, did not work, intercepted ctrl-p (\u0010) (same as up arrow action) and replaced with "Ctl+V+Ctl+P", then "Ctrl+V+Ctrl+P", then just "Ctrl+P", the CLI evaluates it with
in return
Thanks for the info about cli_read, the async option would have been very handy
