EEM Applet Help
I posted this once already, but thought I might have more success here.
Currently Being Moderated
EEM Assistance
I have Redundant WAN's, I want track the availability of both from the Core Nexus 7K, if either WAN is Lost, I want to apply a Service Policy that will remark Video Traffic to DSCP 10. I have the following.
track 120 ip route 10.223.0.120/30 reachability  {the CE to PE link on Wan1}
track 124 ip route 10.223.0.124/30 reachability  {the CE to PE link on Wan2}
track 401 list boolean and
  object 120
  object 124
class-map type qos match-all VIDEO
  match dscp 34
policy-map type qos VIDEO_STOP
  class VIDEO
    set dscp 10
event manager applet VIDEO_STOP
  event track 401 state down
  action 1.0 cli command "enable"
  action 2.0 cli command "config t"
  action 3.0 cli command "int e8/23"
  action 4.0 cli command "service-policy output VIDEO_STOP"
  action 5.0 cli command "int e8/24"
  action 6.0 cli command "service-policy output VIDEO_STOP"
  action 7.0 cli command "end"
labCDCNX1-CS1# sh event manager policy internal VIDEO_STOP
                   Policy Type : applet
           Event Specification : event track 401 state down
                        Action : 1.0,vsh,sup:command "enable";2.0,vsh,sup:comman
d "config t";3.0,vsh,sup:command "int e8/23";4.0,vsh,sup:command "service-policy
output VIDEO_STOP";5.0,vsh,sup:command "int e8/24";6.0,vsh,sup:command "service
-policy output VIDEO_STOP";7.0,vsh,sup:command "end"
Event Specification active on : Standby, Active
labCDCNX1-CS1#
But when I meet the tracking criteria, the policy-map is not appied, I plan to do the reverse when the Track 401 state returns to UP
Mark
EEM Applet Help
Do you see the tracked object 401 going down?  The way it's written, it will go down if either the route 120 or the route 124 goes down.
NX-OS EEM is a different beast that IOS EEM.  I do not think you need "enable" with NX-OS applets.
EEM Applet Help
Yes the tracking function is working correctly,
labCDCNX1-CS1# sh track
Track 120
  IP Route 10.223.0.120/30 Reachability
  Reachability is DOWN
  12 changes, last change 00:01:30
  Tracked by:
    Track List  401
Track 124
  IP Route 10.223.0.124/30 Reachability
  Tracked by:
    Track List  401
Track 401
  List  Boolean and
  Boolean and is DOWN
  Track List Members:
  object 124 DOWN
  object 120 DOWN
I remove the enable command but it still does't run properly, the debug isn't much help,
2012 Mar 10 00:15:09.742257 evmc: avl_ev_type_info_cmp_func: Found ev_type:123393 name:track
2012 Mar 10 00:15:09.742275 evmc: evmc_policy_get_policy_info_by_id: Trying to find policy with id:1426735104
2012 Mar 10 00:15:09.742367 evmc: Malloc in fu_hashtable_2012 Mar 10 00:15:09.742425 evmc: evmc_util_fix_action_spec: No validation for vsh commands
2012 Mar 10 00:15:09.742485 evmc: evmc_util_fix_action_spec: No validation for vsh commands
2012 Mar 10 00:15:09.742497 evmc: evmc_util_fix_action_spec: No validation for vsh commands
2012 Mar 10 00:15:09.742507 evmc: evmc_util_fix_action_spec: No validation for vsh commands
2012 Mar 10 00:15:09.742520 evmc: evmc_util_fix_action_spec: The formatted action spec: 2.0,vsh,sup:command "config t";3.0,vsh,sup:command "int e8/23";4.0,vsh,sup:command "service-policy output VIDEO_STOP";5.0,vsh,sup:command "int e8/24";6.0,vsh,sup:command "service-policy output VIDEO_STOP";7.0,vsh,sup:comman
2012 Mar 10 00:15:09.742553 evmc: evmc_enqueue_action: Trying to enqueue an action
2012 Mar 10 00:15:09.742577 evmc: evmc_enqueue_action: Enqueueing an action
2012 Mar 10 00:15:09.745207 evmc: evmc_exec_action: Starting with policy VIDEO_STOP
2012 Mar 10 00:15:09.745254 evmc: evmc_exec_cmd: Executing command
2012 Mar 10 00:15:09.745291 evmc: fu_fsm_context_set_out_flag: Setting Context flags:   ^IFU_FSM_CONTEXT_FLAG_DONT_DROP_MTS_MSG
2012 Mar 10 00:15:09.745307 evmc: fu_fsm_execute_all: match_msg_id(0), log_already_open(0)
2012 Mar 10 00:15:09.745318 evmc: fu_fsm_execute_all: null fsm_event_list
2012 Mar 10 00:15:09.745327 evmc: fu_fsm_engine_post_event_processing
2012 Mar 10 00:15:09.745337 evmc:  end of while in fu_fsm_engine
2012 Mar 10 00:15:09.745347 evmc: begin fu_fsm_engine: line[2314]
2012 Mar 10 00:15:09.872099 evmc: fu_priority_select:  - setting fd[7] for select call  - setting fd[8] for select call
2012 Mar 10 00:15:09.872124 evmc: fu_priority_select_select_queue: round credit(78)
2012 Mar 10 00:15:09.872134 evmc:     curr_q - FU_PSEL_Q_CAT_CQ, usr_q_info(1), priority(7), credit(5), empty
2012 Mar 10 00:15:09.872147 evmc: fu_priority_select: returning FU_PSEL_Q_CAT_MTS queue, fd(8), usr_q_info(4)
2012 Mar 10 00:15:09.872192 evmc: evmc_get_data_from_queue(775): dequeued mts msg (16450078), MTS_OPC_MVSH_EXEC_CMDS_DONE
2012 Mar 10 00:15:09.872214 evmc: fu_sdb_publisher_invoke_app_callback:App is not a publisher;Bail-out.
2012 Mar 10 00:15:09.872230 evmc: fsrv_sdb_process_msg: vdc-id[2] mts_opc[3092][MTS_OPC_MVSH_EXEC_CMDS_DONE] 0x80d28b0 0xb5d70674 300
2012 Mar 10 00:15:09.872243 evmc: fu_fsm_engine: fsrv_sdb_process_msg ret 0x0
2012 Mar 10 00:15:09.872253 evmc: fu_fsm_engine: fsrv_sdb_process_msg continue ret 0x0
2012 Mar 10 00:15:09.872268 evmc: fu_sync_pss_to_standby_apply:Set of checks failed
2012 Mar 10 00:15:09.872281 evmc: fu_sdb_handle_update: validation fail
2012 Mar 10 00:15:09.872297 evmc: fu_sdb_handle_update: validation fail,                        fu_is_state_active = 1,                        fu_is_sync_pss_to_standby_enabled = 0,                        mts_sync_event_get(mts_msg) = 0,                             create_del) = 0
2012 Mar 10 00:15:09.872313 evmc: evmc_handle_eh_resp: evmc_handle_eh_resp: rid = 0x176b06
2012 Mar 10 00:15:09.872518 evmc: evmc_eh_done: evmc_eh_done
What is "No validation for vsh commands "?
EEM Applet Help
I was able to fix this the IOS Syntax is different than NXOS syntax
I have
  action 1.0 cli config t
  action 2.0 cli int e8/23
  action 3.0 cli service-policy output VIDEO_STOP
  action 4.0 cli int e8/24
  action 5.0 cli service-policy output VIDEO_STOP
  action 6.0 cli end
and it now works
EEM Applet Help
Heh.  I'm so used to the IOS syntax, I missed the errant "command" keyword.  Thanks for the follow-up.  Glad it's working for you.
1280
