04-28-2015 09:14 AM
Hi All,
I'm not sure what the issue is, but I've created an SSH Applet to log into an ASA from an ISR. If I debug, I see that it logs in, and sends "enable" but never gets a "Password:" response.
Here's the script:
event manager applet FIREWALL
event action timer watchdog time 60
action 1.0 cli command "enable"
action 2.0 cli command "ssh -l username 1.1.1.1" pattern "assword:"
action 3.0 cli command "SecretPassword00**" pattern ">"
action 4.0 cli command "enable" pattern "assword:"
action 5.0 cli command "enablePassword123!@#" pattern "#"
action 6.0 cli command "show conn address 2.2.2.2"
action 7.0 cli command "exit"
action 8.0 cli command "exit"
I believe these are all the relevant logs.
%HA_EM-6-LOG: FIREWALL : DEBUG(cli_lib) : : OUT : FIREWALL>
%HA_EM-6-LOG: FIREWALL : DEBUG(cli_lib) : : IN : enable
%HA_EM-6-LOG: FIREWALL : DEBUG(cli_lib) : : CTL : cli_close called
04-29-2015 09:04 AM
You might try relaxing the pattern. Maybe try .* to see what you get. Of course, you should run through this exact thing manually from the router to see exactly what you see at each step.
04-29-2015 01:57 PM
Hi Joseph! Thanks for the response. I changed the pattern from line 4.0 down to "*", but I have the same results. I even tried removing the patterns with no change.
04-29-2015 06:39 PM
A * by itself is wrong. You need to use ".*". But have you tried these same sequence of commands manually from the same router? Are the prompts what you expect?
