EEM help - cli_result
Hi looking for some help with my EEM script to check sip-ua register status
See below
event manager applet checksipregister
description applet to do a show run command to check SIP registration. If not registered, a critical syslog will be created. Runs every 300 seconds.
event timer watchdog time 300
action 1 cli command "show sip-ua register status | include no"
action 2 string length "$_cli_result"
action 3 if $_string_result gt 10
action 4 syslog priority critical msg "SIP status is not registered. Please check service."
action 5 end
Output of commands
When trunk is down
ef-dc-vgw02-r2c6#show sip-ua register status | i no
99051000229971                   -1         86           no
When trunk is up
(no output)
Without pipe
Line                             peer       expires(sec) registered P-Associ-URI
99051000229971                   -1         239          yes
unfortuently the script keeps sending triggering when the trunk is up.
2 ACCEPTED SOLUTIONS
You likely want to do this:
action 1.0 cli command "enable"
action 2.0 cli command "show sip-ua register status | include no"
action 3.0 regexp "[0-9]+.*no" $_cli_result
action 4.0 if $_regexp_result eq 1
action 5.0  syslog priority critical msg "SIP status is not registered.  Please check service."
action 6.0 end
You need to add:
event manager session cli username USER
Where USER is a user authorized to run all of the CLI commands in this applet.
action 6.0 end
Thanks Joseph,
I gave that one a try however it didn't trigger, is it becouse of the - in the output?
Thanks for your help.
No.  It works for me in local testing.  Are you sure you copied the regular expression correctly?  What does "debug event manager action cli" report when the applet runs?
Thanks for the reply, see results from the debug.
ef-dc-vgw02-r2c6#
*Mar  3 15:57:21: %HA_EM-6-LOG: checksipregister : DEBUG(cli_lib) : : CTL : cli_open called.
*Mar  3 15:57:21: %HA_EM-6-LOG: checksipregister : DEBUG(cli_lib) : : OUT : ef-dc-vgw02-r2c6#
*Mar  3 15:57:21: %HA_EM-6-LOG: checksipregister : DEBUG(cli_lib) : : IN  : ef-dc-vgw02-r2c6#enable
*Mar  3 15:57:21: %HA_EM-6-LOG: checksipregister : DEBUG(cli_lib) : : OUT : % Authorization failed.
*Mar  3 15:57:21: %HA_EM-6-LOG: checksipregister : DEBUG(cli_lib) : : IN  : ef-dc-vgw02-r2c6#show sip-ua register status | include no
*Mar  3 15:57:22: %HA_EM-6-LOG: checksipregister : DEBUG(cli_lib) : : OUT : ef-dc-vgw02-r2c6#
*Mar  3 15:57:22: %HA_EM-6-LOG: checksipregister : DEBUG(cli_lib) : : CTL : cli_close called.
*Mar  3 15:57:22: tty is now going through its death sequence
Perfomed by me
99051000229971                   -1         83           no
ef-dc-vgw02-r2c6#
You need to add:
Thanks heaps Joseph! All setup
and how change above script
and how change above script ,to send the router to wr and reload if 1 SIP account is missing in "sh sip-ua register status"
636
