09-24-2014 08:35 AM
There is no trace of EEM on my router. I have an 861 running universal 15.0(1)M4 with an advsecurity licensce.
This is what I get under global config:
lch-nj_mana(config)#e?
enable end energywise eou
errdisable exception exit
Am I going crazy? Why isn't event an option?
Solved! Go to Solution.
09-29-2014 12:46 PM
The 860 product team made a decision to remove EEM starting in 15.0 code. You would need to downgrade to 12.4 or move to another 800 series like the 881 or 891.
09-26-2014 12:58 PM
Please post the output of "show version" from this router.
09-26-2014 01:13 PM
Cisco IOS Software, C860 Software (C860-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 23:49 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
lch-nj_mana uptime is 4 days, 7 hours, 25 minutes
System restarted at 08:48:01 EDT Mon Sep 22 2014
System image file is "flash:c860-universalk9-mz.150-1.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 861 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX151401HQ
5 FastEthernet interfaces
1 Gigabit Ethernet interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO861W-GN-A-K9 FTX151401HQ
License Information for 'c860-data'
License Level: advsecurity Type: Permanent
Next reboot license Level: advsecurity
09-29-2014 12:46 PM
