EEM on 2960S LANBASE?
Howdy all.
I'm hoping someone can help answer whether EEM is supported on a 2960S switch with LANBASE (not LAN Lite). I'm running 12.2(55)SE9 UNIVERSAL, which, according to Feature Navigator, supports EEM 3.2.
When I try to configure event manager on the CLI, the command is unrecognized.
I have tried this under both the default and lanbase-routing SDMs.
Justin
1 ACCEPTED SOLUTION
The 2960 only supports EEM
The 2960 only supports EEM-lite (to drive auto smart ports).  You will not be able to configure your own EEM policies.
Good to know. Thanks Joe! I
Good to know. Thanks Joe! I was hoping the EEM guru would chime in. :)
I am not able to configure
I am not able to configure EEM script on  WS-C2960-24TC-L running c2960-lanbasek9-mz.150-2.SE7.bin.
Here is the error message.
IND-HYF-CON-ACC-SW-0(config)#event manager
% Invalid input detected at '^' marker.
IND-HYF-CON-ACC-SW-0(config)#e?
eap enable end energywise
epm errdisable exception exit
Not getting option for any command like event manager.
As already stated in this
As already stated in this thread, EEM is not supported on the 2960 series.   Only EEM-Lite is supported, and this means you cannot configure your own policies.
440
