Webcast-Catalyst9k
EEM Script is not removing the disable port from suspend_port.dat by seeing syslog port up message
Dears, I am trying to disable the inactive port by using your provided script sl_suspend_ports.tcl and tm_suspend_ports.tcl. I am using a cisco 3560 8 port switch with below scenario. All the switch ports are admin enabeld and not in connected state. I configured the suspend_ports_config as 2 days.
Day 0
SCript has been ran and put all the ports in Suspend_port file.
Day 1
Script again ran, maintain all the ports are in suspend_port file.
Note:- After ran the script, i enabled fs 0/6 switch port and then made it down. One syslog up down event has been logged in the Cisco switch.
Day 2
Script ran again and disabled all the ports.
Ideally it should not disable the port fa0/6. As per my understanding sl_suspend_ports.tcl script keep monitors the syslog port up messages and remove the interfaces from suspend_port file if any ports up. I suspect some issues with this sl_suspend_ports.tcl script. Please find the attached configuration and the scripts. Kindly advice me on this as I am very much cusios to install these scripts which will reduce my overhead.
Please find the swich configuration as below.
DCSWTICH#show running-config | include vent
event manager environment suspend_ports_days 2
event manager environment suspend_ports_config flash:/susp_ports.dat
event manager directory user policy "flash:/policies"
event manager policy sl_suspend_ports.tcl
event manager policy tm_suspend_ports.tcl
DCSWTICH# irectory of flash:/ 2 -rwx 796 Mar 1 1993 22:22:11 +00:00 vlan.dat 3 -rwx 218 Jan 17 2013 00:00:01 +00:00 susp_ports.dat 4 drwx 512 Mar 1 1993 00:35:07 +00:00 policies 6 -rwx 24 Jan 17 2013 01:54:39 +00:00 private-config.text 5 -rwx 4555 Mar 1 1993 00:44:03 +00:00 tm_suspend_ports.tcl 90 -rwx 2072 Jan 17 2013 01:54:39 +00:00 multiple-fs 91 -rwx 3101 Mar 1 1993 00:44:32 +00:00 sl_suspend_ports.tcl 8 drwx 512 Mar 1 1993 00:49:39 +00:00 c3560-ipbasek9-mz.122-55.S E7 93 -rwx 3093 Jan 17 2013 01:54:39 +00:00 config.text 27998208 bytes total (15520768 bytes free) DCSWTICH# Regards, Jubair Salim.
1 ACCEPTED SOLUTION
Re: EEM Script is not removing the disable port from suspend_por
Try this version.
You have not provided enough information to understand what is happening.  Post the susp_ports.dat file as well as the syslogs that were generated when Fa0/6 was brought up.
Thanks for the reply Clark. Please find the tested scenario as below.
All ports were physically down in 8 port Cisco 3560 switch
Day1
Script ran and stored all the ports in sus_ports.dat
Day 2
Note:- I enabeld the port fa0/6 after the script run and after then made it as physically down by removing the cable.
Day 3
Script run and disabled all the port.
Please find the attached sus_ports.dat file, syslog and show flash output as attached.
Is there any timer has been confgured in sl_supend_ports script to check the link up information or will it automatically fetch the date once the link up.
Try this version.
Thanks a lot Joseph...It is working.....It is removing the ports as per the syslog message as of now...
Just wanted to say thanks for
Just wanted to say thanks for these amazing scripts!
1353
