08-08-2013 03:10 AM
Is it possible to write an EEM script that opens a telnet session, authenticates, executes few commnads and than closes it back again?
I was trying to do this with Tcl lately. Unfortunatelly once I open the session from the Tcl shell, I don't have an option to read the outputs and send characters in the Telnet session. The only option is to enter the commands manually...
Solved! Go to Solution.
08-09-2013 06:24 PM
Sure, this is possible. I have a script that wraps the IOS telnet command to do exactly what you're saying. You can get it from http://www.cisco.com/assets/cdc_content_elements/docs/ios/eas/easy-shell.tar .
08-09-2013 06:24 PM
08-19-2013 01:52 AM
Joseph,
This is amazing! I've briefly looked at the script and it indeed does exactly what I'm looking for And... a lot more off course. Amazing, thanks for sharing.
Boyan
