Hall of Fame Super Gold
EEM Script to set port names from CDP results
I've been using THIS, which Joe has modified.  The script checks the CDP table and only works on routers, switches and wireless access points.  The problem is that the access point doesn't seem to work.  Here's Joe's script:
event manager applet update-port
 event neighbor-discovery interface regexp GigabitEthernet.* cdp add
 action 100 regexp "(Switch|Router|Trans-Bridge)" "$_nd_cdp_capabilities_string"
 action 110 if $_regexp_result eq "1"
 action 200  cli command "enable"
 action 210  cli command "config t"
 action 220  cli command "interface $_nd_local_intf_name"
 action 230  regexp "^([^\.]+)\." "$_nd_cdp_entry_name" match host
 action 240  cli command "description $host"
 action 500 end
And the error I am getting is:
May  5 12:23:48 AEST: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: host
May  5 12:23:48 AEST: %HA_EM-3-FMPD_ERROR: Error executing applet update-port statement 240
The "sh cdp neighbors detail" result of a wireless access point is:
Device ID: Device
Entry address(es):
  IP address: 10.227.99.249
Platform: cisco AIR-LAP1142N-N-K9,  Capabilities: Router Trans-Bridge
Interface: GigabitEthernet4/48,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 158 sec
Version :
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.2(4)JB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 06-Mar-14 11:37 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 15.400 Watts
Power request id: 33353, Power management id: 2
Power request levels are:15400 14500 0 0 0
Management address(es):
Would appreciate if someone can help me fix this.
Thanks in advance.
1 ACCEPTED SOLUTION
There is no trailing dot.  So
There is no trailing dot.  So you need to use a regexp of either:
Or:
If you're ID is really
Device ID: Device
Then your regexp won't match.  You could likely add a '?' at the end of the pattern to indicate the trailing '.' is not required.
Joe,  I substituted the
Joe,
I substituted the Device ID of the wireless access point.  Device ID is the hostname of the wireless access point which has the following syntax:  SITEasset.
Best Regards/Leo
If you print the value of $
If you print the value of $_nd_cdp_entry_name, what do you get?  Do not sanitize this as it will be important to see why the regexp is not matching.
Hi Joe,
Thanks.
EEM is totally out of my league here.  How do I "print the value of $_nd_cdp_entry_name"?
Add: action 221 syslog msg
Add:
action 221 syslog msg "XXX: '$_nd_cdp_entry_name'"
May 6 08:56:54 AEST: %HA_EM
May  6 08:56:54 AEST: %HA_EM-6-LOG: update-port: XXX: 'CLRM197230'
May  6 08:56:54 AEST: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: host
May  6 08:56:54 AEST: %HA_EM-3-FMPD_ERROR: Error executing applet update-port statement 240
Un-sanitized output above, Joe.
Thanks for sharing your expertise here.  laugh
Or:
This is in line 230, right
This is in line 230, right Joe?
I'll give this a try tomorrow.
Thanks Joe!  laugh
Thanks Joe.  It's working.  :
Thanks Joe.  It's working.  laughlaughlaugh
453
