03-27-2014 12:14 PM
I am trying to extract the numerical value from the followng using Embedded event manager(TCL Scripting)
i also have SLA probes running between 2 connected routers
sho ip sla statistics | sec SD Jitter
So i write the the following
conf ter
event manager applet STAT
event none sync yes
action 1 cli command "enable"
action 2 cli command "sho ip sla stat | sec SD Jitter"
action 3 regexp " [0-9]+ " $_cli_result result
action 4 puts "$result"
However it produces result
*Mar 27 16:42:08.806: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: result
*Mar 27 16:42:08.806: %HA_EM-3-FMPD_ERROR: Error executing applet STAT statement 4
pls clarify
03-31-2015 09:26 AM
hello - I have just moved your post to the Topic forums - you had posted your question in an obscure, non-visible, promotional community. Hopefully our community users will see your question now
04-16-2015 04:48 AM
Does the "show ip sla stat | sec SD Jitter" show any output with numbers? If not, then the result variable will not be populated. Try adding line 2 below into your applet so if there is not a match it will not produce an error.
event none sync yes
action 2 set result "No match"
action 3 cli command "sho ip sla stat | sec SD Jitter"
action 4 regexp " [0-9]+ " $_cli_result result
action 5 puts "$result"
