Webcast-Catalyst9k
EEM SMTP issue on IOS-XR
friends,
i am trying simple eem script to send email alert on log message (IOS XR 4.3.1)..  but i am getting following error;
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan: error connecting to mail server:
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan: cannot connect to all the candidate mail servers
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan:     while executing
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan: "smtp_send_email $mail_msg"
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan:     invoked from within
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan: "if [catch {smtp_send_email $mail_msg} result] {
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan:     error $result $errorInfo
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan: }
RP/0/RSP0/CPU0:Jan 24 21:04:17.776 : syslog_dev[92]: noscan:     (file "/dev/rdsfs/etc/eem_rdsfs/config_done.tcl" line 26)
==== EEM Script ====
::cisco::eem::event_register_syslog pattern {%MGBL-SYS-5-CONFIG_I}
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
set mail_pre "Mailservername: 1.1.1.254\n"
append mail_pre "From: nms@isp.com\n"
append mail_pre "To: asad@isp.com\n"
append mail_pre "Cc: \n"
append mail_pre "Sourceintf: Loopback0\n"
append mail_pre "Subject: Some Configuration Done\n\n"
append mail_pre "Some weird Configuration is Done on ASR 9010. Take Immediate Action\n\n"
set mail_msg [uplevel #0 [list subst -nobackslashes -nocommands $mail_pre]]
I can connect to SMTP server from Router CLI using source-interface
RP/0/RSP0/CPU0:ASR-9010#telnet 1.1.1.254 25 source-interface loopback 0
Trying 1.1.1.254...
Use specified source interface(Loopback0).
Use 1.1.1.254 as local address.
Connected to 1.1.1.254.
Escape character is '^^'.
220 smtp.isp.com ESMTP Postfix
221 2.0.0 Bye
1 REPLY
I do not think your version of XR supports the source interface option.  You can check the smtp_lib.tcl on your router to confirm.  On IOS, this is in tmpsys:/lib/tcl.  I can't recall off the top of my head where this resides on XR, but if you hunt around the various file systems you will find it.
469
