EEM to apply Smart Port Macro
I use macros to configure access ports and voice ports, here is a sample of how it is called.
interface range GigabitEthernet1/0/20 - 24
macro apply cisco-voice $access_vlan 10 $voice_vlan 20
I am trying to call this in an EEM script but am getting the error below.
000954: .Jun 29 16:16:24.937 CEST: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: access_vlan
000955: .Jun 29 16:16:24.937 CEST: %HA_EM-3-FMPD_ERROR: Error executing applet POST_PNP statement 1.7
I have messed around with a set variable but am not sure I am going in the right direction.
conf t
no event manager applet POST_PNP
 event timer countdown time 5
 action 1.0 cli command "enable"
 action 1.1 cli command "config t"
 action 1.2 cli command "default interface range GigabitEthernet1/0/20 - 24"
 action 1.5 cli command "interface range GigabitEthernet1/0/20 - 24"
 action 1.6 set ???
 action 1.7 cli command "macro apply cisco-voice $access_vlan 10 $voice_vlan 20"
 action 2.0 cli command "exit"
 action 2.1 cli command "no event manager applet POST_PNP"
 action 2.2 cli command "end"
 action 2.3 cli command "exit"
exit
end
Here is the full macro
test#show parser macro name cisco-phone
Macro name : cisco-phone
Macro type : default interface
# Cisco IP phone + desktop template
# macro keywords $access_vlan $voice_vlan
# VoIP enabled interface - Enable data VLAN
# and voice VLAN
# Recommended value for access vlan should not be 1
switchport access vlan $access_vlan
switchport mode access
# Update the Voice VLAN value which should be
# different from data VLAN
# Recommended value for voice vlan should not be 1
switchport voice vlan $voice_vlan
# Enable port security limiting port to a 2 MAC
# addressess -- One for desktop on data vlan and
# one for phone on voice vlan
switchport port-security
switchport port-security maximum 2
# Ensure port-security age is greater than one minute
# and use inactivity timer
switchport port-security violation restrict
switchport port-security aging time 2
switchport port-security aging type inactivity
# Enable auto-qos to extend trust to attached Cisco phone
auto qos voip cisco-phone
# Configure port as an edge network port
spanning-tree portfast
spanning-tree bpduguard enable
1 ACCEPTED SOLUTION
I don't mix EEM and macros.
I don't mix EEM and macros.  They both use '$' to denote variables, and in this case EEM is winning and complaining it cannot find those variables (and you don't want it to).
What I would recommend is to copy your whole macro into EEM and use EEM (if you want to) to apply the whole config.  This is similar to what I do in https://supportforums.cisco.com/document/100791/automatically-set-port-descriptions .
If you do not want to do that, you'll need to create a variable to stand for the variables:
event manager environment av $access_vlan
event manager environment vv $voice_vlan
Then:
macro apply cisco-voice $av 10 $vv 20
1 REPLY
Then:
139
