EEM to extract IP addr from syslog
Hi all
Very new to this EEM.
I'm working with PFR/OER and want to do a few things when a certain msg is in the logs
The Syslog msg is
%PFR_MC-6-OOP_ACTIVE_MODE: Active REL Unreachable OOP Prefix 10.154.0.0/16, unreachable 50000, BR 10.255.65.20, i/f Gi0/3, relative change 1025, prev BR Unknown i/f Unknown
When message is "%PFR_MC-6-OOP_" is sysloged ..
I want to execute a few commands using the IP prefix in the log (10.154.0.0/16 in the example) and echo the CLI output to the log and screen
I have a simple EEM working that writes 'WOOHOO' when it detects the string.
But i don't know how to extract the IP address .. nor do I know how to redirect the CLI output to the syslog.
event manager applet PFRMON1
event syslog pattern "%PFR_MC-6-OOP"
action 1.0 syslog msg "WhooHoo PFR OOP"  facility 3
Any help would be appreciated
Wes
Message was edited by: Wes Smith For example using the msg above .. I want to extract 10.154.0.0/16 and use it as follows .. with the cmd output going to syslog and optionally the screen sh pfr master traffic-class prefix 10.154.0.0/16 detail sh pfr master prefix 10.154.0.0/16 detail
Everyone's tags (3)
1 ACCEPTED SOLUTION
You can do this:
action 1.0 regexp "Prefix ([^,]+)," $_syslog_msg match prefix
action 2.0 cli command "enable"
action 3.0 cli command "show pfr master traffic-class prefix $prefix detail"
action 4.0 syslog msg "$_cli_result"
You can do this:
Re: EEM to extract IP addr from syslog
Thanks very much Joseph.
I have the following script working .  The syslogs are Priority 3 and have a Faclity of 'WES"
My only remaining problem is action 1.0.
I'm trying to send the entire source syslog msg to the log with Pri 3 Fac "WES"  but it's not doing it.
I likely have the string wrong,.    Dumb question .. where are the strings like $_syslog_msg defined ?
action 1.0 syslog priority errors msg "$_syslog_msg" facility "WES"
action 2.0 regexp "Prefix ([^,]+)," "$_syslog_msg" match prefix
action 3.0 cli command "enable"
action 4.0 cli command "show pfr master traffic-class prefix $prefix detail"
action 5.0 syslog priority errors msg "$_cli_result" facility "WES"
action 6.0 cli command "show pfr master  prefix $prefix detail"
action 7.0 syslog priority errors msg "$_cli_result" facility "WES"
action 8.0 cli command "show pfr mast learn list"
action 9.0 syslog priority errors msg "$_cli_result" facility "WES"
I was wrong.  It is doing it.
I was searching the log for the word WES and the output is formatted as follows
The 1st msg from the script is "%WES-3-LOG: PFRMON1: " with the Sev 3 and WES code
The rest of them are just raw text dump to syslog .
991023: Oct 10 19:59:18.719 edt: %WES-3-LOG: PFRMON1:
991021: Oct 10 19:59:18 edt: %PFR_MC-6-OOP_ACTIVE_MODE: Active ABS Delay OOP Prefix 10.171.0.0/17, delay 104, BR 10.255.65.20, i/f Gi0/3
991024: Oct 10 19:59:18.751 edt: %WES-3-LOG: PFRMON1:
OER Prefix Statistics:
Pas - Passive, Act - Active, S - Short term, L - Long term, Dly - Delay (ms),
P - Percentage below threshold, Jit - Jitter (ms),
Yeah, syslog is not the best delivery mechanism for multi-line output.  Something like email would be better.
Each event detector defines its own variables.  Look at "show event manager detector DETECTOR detail" for a list of variables per DETECTOR.
895
