05-12-2014 03:31 AM
Hello
I want to create a script that give me total traffic of a switch with embedded event manager.
anyone help me please
05-12-2014 06:42 AM
Define "total traffic of a switch." Do you mean a sum of input and output bytes per port? Backplane traffic? How would you measure this manually? What do you want to do with this data? How should the EEM policy be triggered?
05-12-2014 08:15 AM
that is to say, I want to make a EEM script that gives me incoming traffic and outgoing traffic and finally I give her total traffic calculation
this is my mentor who give me this works but I do not know how.
Josph thank you for helping me.
05-12-2014 12:22 PM
I'm still not clear on what you want. Do you just want the sum of the interface stats to be printed out on the terminal on demand? How should this policy be triggered?
05-21-2014 03:09 AM
Hello Joseph
I want to calculate sum of input and output bytes per port.
I did a test: I work with command "show interface f0/0", this command shows us a sentence contains input end output bytes, now if my method is correct how do I extract the value of input and output of this sentence to calculate traffic total.The display is the next :
30 second input rate 54000 bits/sec, 98 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
05-27-2014 02:29 PM
Okay, I still don't know how you want to execute this, but I can give you some hints. I leave it to you to assemble the policy based on your requirements.
To get a list of interfaces and sum the total bps, use the following series of actions (note: I assume an applet policy):
set itotal 0
set ototal 0
cli command "enable"
cli command "show ip int brief"
set intfs "$_cli_result"
foreach line $intfs "\n"
regexp "^([A-Za-z]+Ethernet[0-9/\.])" $line match intf
if $_regexp_result eq 1
cli command "show interface $intf | inc rate"
regexp "input rate ([0-9]+)" $_cli_result match irate
regexp "output rate ([0-9]+)" $_cli_result match orate
add $itotal $irate
set itotal $_result
add $ototal $orate
set ototal $_result
end
end
