Event None to Test Script
Hello Community,
Can someone kindly show me how to tweak the attached script to allow me to issue the command:
event manager run WanUtilisationwan_load_alarm.tcl
I've tried tweakinging the script in the event register but failed.
Basically, I would like to test the script.
Cheers
Carlton
Joe, if you're going to help, jus thought I'd let you know I watched some of your cisco live recording. Good to put name to face. And they were very educational.
Cheers
1 REPLY
You're first line looks fine except you forgot to tweak maxun.  You'll need to set that to an acceptable value like 120 or whatever you found works.
257
