Execute Hidden/Undocumented CLI Commands
tim.braxmaier
I am running into an issue running some undocumented/hidden CLI commands via the EEM Applet.
I guess this is due to the fact that the Applet checks whether the CLI Command exists and the command is "hidden" .
Is there a way to disable CLI Command Check or possiby enable hidden commands specifically?
Best regards,
Tim
EDIT:
Specifically it is concerning show list in the following Applet:
event manager applet memory_outputs
event timer cron cron-entry "* */4 * * *"
action 010 cli command "enable"
action 020 cli command "terminal exec prompt timestamp"
action 030 cli command "show processes memory sorted | redirect tftp://10.10.10.20/show_process_cpu_sorted$_event_pub_sec"
action 040 wait 10
action 050 cli command "show memory alloc totals | redirect tftp://10.10.10.20/show_memory_alloc_totals$_event_pub_sec"
action 060 wait 10
action 070 cli command "show list | redirect tftp://10.10.10.20/show_list$_event_pub_sec"
action 080 wait 10
action 090 cli command "end"
But it seems show list is not executed due to the default maxrun of 20 seconds. I have not had the chance to confirm this...
Joe Clarke
Yeah, you definitely need to add "maxrun 50" (or higher) for this applet.  Note: you can execute any CLI command via EEM that you can manually.  EEM uses the same VTY infrastructure for executing CLI commands.
Joe Clarke
