You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
HELP Using EEM
Im trying to use EEM to check the output of "show interface description | include TEST" to shutdown all ports with the description TEST. Was wondering if anyone had any ideas
  • EEM Scripting
HELP Using EEM
Here is a .tcl EEM policy which should help.  It does some extra checking to narrow by interface type.  You can
remove that if needed.
Thanks.
::cisco::eem::event_register_none maxrun 120 default 120
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
# 1. execute cli commands to gather data
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} result] {
if [catch {cli_exec $cli1(fd) "show int desc | in TEST"} cli_show_int] {
    error $cli_show_int $errorInfo
foreach line [split $cli_show_int \n] {
    set match1 [regexp {^[F|G|T][a|i|e][0-9|/]+} $line match]
    if {$match1 == 1} {
        if [catch {cli_exec $cli1(fd) "conf t"} result] {
        if [catch {cli_exec $cli1(fd) "interface $match"} result] {
        if [catch {cli_exec $cli1(fd) "shutdown"} result] {
        if [catch {cli_exec $cli1(fd) "end"} result] {
        puts "shutting interface $match"
    } else {
        puts "skipping interface $line"
HELP Using EEM
Here is a sample EEM applet which does this as well:
event manager applet desctest
event none
action 100 cli command "enable"
action 101 cli command "show int descr | inc TEST"
action 102 foreach line "$_cli_result" "\n"
action 103 regexp "([^\s]*).*TEST.*" $line match _int
action 104 puts "line is --$line--"
action 105  if $_regexp_result eq "0"
action 106   puts "Interface is $_int"
action 107   cli command "conf t"
action 108   cli command "interface $_int"
action 109   cli command "shutdown"
action 110  end
action 111 end
345
