Help with custom EEM (collect top)
So ... whats wrong with this ? lol
event manager environment quote "
event manager applet top-interface-counter
event cli pattern "topint" sync yes
action 1 cli command "collect top 10 counters interface all interval 10"
action 2 cli command "event manager applet int-pause"
action 2.1 cli command "enable"
action 2.2 cli command "event timer countdown time 11"
action 2.3 cli command "action 1.0 cli command $quoteshow top counters interface report 1"
action 2.4 cli command "action 2.0 cli command $quoteno event manager applet int-pause"
action 2.5 cli command "action 3.0 cli command end"
action 3 cli command "event manager applet int-clear"
action 3.1 cli command "enable"
action 3.2 cli command "event timer countdown time 3"
action 3.3 cli command "action 1.0 cli command $quote clear top counters interface report"
action 3.4 cli command "action 2.0 cli command $quote no event manager applet int-clear"
action 3.5 cli command "action 3.0 cli command end"
action 4 cli command "end"
First, is there an existing command in IOS with "topint" in its structure?  If not, this will fail outright.  You'd need to change the event line to:
event cli pattern "topint" enter
Next, you must put a space between $quote and the start of your command and add another $quote at the end of the command:
action 2.3 cli command "action 1.0 cli command $quote show top counters interface report 1$quote"
Next, you do not enter "config t" mode before you configure your nested applets.  You need to add:
action 2.11 cli command "config t"
You'll also need to enter "config t" mode in your nested applets in order to remove the EEM policies.
Finally, action 3.1 can be deleted.
Thanks for the quick reply
Sorry noticed the small typo's wrote it in a hurry.
I wanted when someone enter's "topint" in CLI it will run the script.
Then you will need to change the event line has I have shown.
613
