Help with large counters
As part of an EEM script I am collecting the bytes downloaded on my WAN interface, formatting it and using it to create a banner with the monthly usage. The numbers get quite large and I am getting the following message:
%HA_EM-6-FMPD_OPERAND_INVALID: Invalid operand in action, expected value within range -2147483648 to 2147483647, received: 4824555627
Is there anyway around this?
Ryan
Re: Help with large counters
Hi Ryan,
I don't know it it's recommendable, but if you really want to do calculations with such large numbers, you could use floating-point values instead of integers:
R1(tcl)#set x 4824555627
4824555627
R1(tcl)#puts [expr $x]
integer value too large to represent
R1(tcl)#puts [expr [format "%.1f" $x]]
4824555627.0
R1(tcl)#puts [expr [format "%.1f" $x] * 10]
48245556270.0
Perhaps you should wait a while for other answers or a confirmation as I'm not very experienced with TCL.
Rolf
Yep, this is the way to go.  You need to use Tcl, and you need to convert to floating point.  One easy way to do the conversion is with:
set num "${num}.0"
Then you can operate on $num like an FP.  This doesn't work with applets, so Tcl is the only way to go.
350
