How do I debug Smartport Macros
I'm trying to get my 2960s to detect the connection of an Access Point and then switch the port from a 802.1.X authenticated port to a trunk.
I have this working to the point where after MAB auth my ISE will specify the Macro to run to reconfigure the port.
The port re-configuration is not happening but the Macro executes … meaning I have an error in my macro.
I cannot see debug information anywhere to trace the execution of the macro.
Docs say in the interface to  issue the command " macro trace CISCO_AP_AUTO_SMARTPORT"
I get the error "% Macro 'CISCO_AP_AUTO_SMARTPORT' does not exist. "
(where CISCO_AP_AUTO_SMARTPORT is a Macro I overwrote to my own purposes )
the port is configured thus :
description Woring on GOLD .x port config here
 switchport access vlan 13
 switchport trunk allowed vlan 1-16
 switchport mode access
 switchport voice vlan 9
 ip access-group ACL-ALLOW in
 no logging event link-status
 load-interval 30
 authentication event fail action next-method
 authentication event server dead action authorize vlan 2
 authentication event server dead action authorize voice
 authentication event server alive action reinitialize
 authentication host-mode multi-auth
 authentication order dot1x mab webauth
 authentication priority dot1x mab webauth
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 authentication violation restrict
 mab
 no snmp trap link-status
 macro description CISCO_AP_AUTO_SMARTPORT
 dot1x pae authenticator
 dot1x timeout tx-period 3
 spanning-tree portfast
end
and the macro being applied it this:
macro auto execute CISCO_AP_AUTO_SMARTPORT  {
 if [[ $LINKUP == YES ]]
  then conf t
  interface  $INTERFACE
  macro description $TRIGGER
  switchport mode trunk
  auto qos voip trust
  mls qos trust cos
  if [[ $LIMIT == 0 ]]
   then default srr-queue bandwidth limit
   else srr-queue bandwidth limit $LIMIT
  fi
  if [[ $SW_POE == YES ]]
   then if [[ $AP125X == AP125X ]]
    then macro description AP125X
    macro auto port sticky
    power inline port maximum 20000
   fi
  fi
  exit
  end
 fi
 if [[ $LINKUP == NO ]]
  then conf t
  load-interval 30
  mab
  if [[ $AUTH_ENABLED == NO ]]
   then no switchport mode
   no switchport trunk encapsulation
  fi
  if [[ $STICKY == YES ]]
   then if [[ $SW_POE == YES ]]
     then no macro auto port sticky
     no power inline port maximum
    fi
   fi
  fi
  exit
  end
 fi
-KK-
134
