10-06-2014 06:22 PM
All our Cisco core switches are using VRF for management.
I would like to setup EEM to send email alarm to me when things happen.
But how can I send email to mail server in different VRF?
Many thanks,
Solved! Go to Solution.
10-06-2014 07:05 PM
Ha,
just found it.
There is a VRF option in the action.
action 8.0 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "Link to Flashdesktop UP" body "Link to Lab circuit UP!" vrf ###
10-06-2014 07:05 PM
Ha,
just found it.
07-08-2015 02:19 AM
Hi, regarding this topic. Can you tell me with IOS version and platform are you using? I'm trying to configure the vrf option on a Cisco 2811 running Version 15.1(4)M8, but I don't have the option.
Thanks!
07-14-2015 02:08 AM
Solved. EEM4.0 required, which is in 15.2(2)T. 2811 doesn't support that image.
