How to copy an IP-Address from CLI output into a variable?
Does anybody know how I can copy the IP address from an output from " ping www.cisco.com" into a variable?
"Sending 5, 100-byte ICMP Echos to 95.100.32.170, timeout is 2 seconds"
Marc
1 REPLY
Re: How to copy an IP-Address from CLI output into a variable?
If you mean using EEM, you cam do that using something like:
set output [cli_run [list "enable" "ping www.cisco.com"]]
if { [regexp {Echos to ([\d\.]+)} $output -> ip] } {
    puts "Address is $ip"
931
