how to shut no shut interface of switch using(EEM) Script for 3560 switch
Dear community experts,
I'm new for creating scripting for EEM and below is my situation, need your support.
Present I'm using 3560 switch, one of  the switch port(FA0/1) has added  Cisco Access point(PoE), actually what happening daily this Access point getting struct when I'M doing the switch port (FA0/1) shut  then no shut it is working fine .
So my question is i need script, that should continuously ping the IP off the Access point if the IP will drop 4 packets the switch do shut  and then no shut for that I need the script, Please help me.
if it is not possible please provide the batch file, which will ping the particular IP if 4 packet drops it will telnet the switch and go to the interface do shut no shut
Note:
instead of mentioned 3560, I mentioned 2960 now corrected it  please provide the script.
1 REPLY
This should work: ip sla 1
This should work:
ip sla 1
 icmp-echo 10.10.10.1
 frequency 15
ip sla schedule 1 life forever start now
ip sla enable reaction-alerts
ip sla reaction-configuration 1 react timeout action-type trapOnly threshold-type consecutive 4
event manager applet reset-ap
 event ipsla operation-id 1 reaction-type timeout
 action 1.0 cli command "enable"
 action 2.0 cli command "config t"
 action 3.0 cli command "int fa0/1"
 action 4.0 cli command "shut"
 action 5.0 cli command "no shut"
 action 6.0 cli command "end"
424
