Webcast-Catalyst9k
Interface status change and show interface descritpion
Hi All,
I am trying to write a script which will mail the status change along with " show inter description" details.
event manager applet interface-down
 event syslog severity-notification pattern "%LINEPROTO-5-UPDOWN: Line protocol on Interface.* changed state to down"
 action 1 regexp "Interface ([^,]+)" "$_syslog_msg" match intf
 action 1.1 cli command "do show interface $intf description"
 action 2 mail server "$email_server" to "$email_to" from "$email_from" subject "Interface status change" body "Interface $intf changed state to down $_cli_result"
end
Issue is ,am not getting the " show inter description". can someone help me on this?
Thanks in Advance
Geevee
1 ACCEPTED SOLUTION
Before action 1.1 EEM needs
Before action 1.1 EEM needs to issue the "enable" command.
Thanks Daniel, that worked
395
