04-22-2018 07:19 AM - edited 03-01-2019 06:32 PM
Hi team,
I have tested in several ways but it does not work,
I have 2 ISPs, so I made the IP SLA for icmp echos to test the public IP 208.67.222.222 that it does not receive a ping icmp's the strack in the static route will know about it
and its supposed to execute the EEM script
When I test and shutdown the other end of the border router to simulate a failure, even the show track 87 shows reachibility down but still the applet does not run
could you please check and help me if the script below is correct of if Im missing something?
ip sla 87
icmp-echo 208.67.222.222 source-ip 192.168.1.1
frequency 5
exit
ip sla schedule 87 life forever start-time now
track 87 ip sla 87 reachability
delay down 8 up 10
event manager applet failover_test
event track 87 state down
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "route-map TEST-PBR"
action 1.3 cli command "no set ip next-hop 10.1.1.1"
action 1.4 cli command "set ip next-hop 10.2.2.2"
action 1.5 cli command "end"
action 1.6 cli command "write memory"
ip route 208.67.222.222 255.255.255.255 10.1.1.1 name EEMScript track 87
Solved! Go to Solution.
04-22-2018 10:10 AM
A track applet will only execute on a state transition. Therefore, track 87 needed to be up first. It's not clear from this that the track actually transitioned state.
If it does transition from Up to Down, then you should check "show event manager history event" to confirm that the policy didn't actually run.
04-22-2018 10:10 AM
05-27-2018 07:27 AM
Thanks, you were right, I actually put the command you suggested to check if it was actually flapping or not,
06-22-2018 05:59 AM
Any chance the final script could be posted as I have the same requirements for my customer ?
06-22-2018 06:28 AM
I don't think any additional changes were needed to the originally posted applet. As I said, EEM only detects state transitions. As long as the tracked object transitioned from up to down, the policy would fire.
06-22-2018 06:43 AM
06-22-2018 06:58 AM
I did not suggest that, nor did I get the impression that happened.
06-22-2018 08:09 AM
Thats true,
I did not modify anything, the script as it is there, it works perfectly,
but that came to my mind as Clarke mentioned,
I issued the show event manager policy registered or show event manager history events so I knew there was something wrong that was not triggering it
once I put the FW rule, denied it, and worked, now the script is functional
hope that helps
