is it possible to create two scripts?
Is it possible this way if I'm making two script? Thanks.
Script 1
For this log:
Apr 24 07:40:01.884 MNL: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state
to down
ROUTER(config)#event manager applet cell1
ROUTER(config-applet)# event syslog pattern "Interface Cellular0/2/0, changed state to down"
ROUTER(config-applet)# action 1.0 cli command "enable"
ROUTER(config-applet)# action 1.1 cli cmmand "configure term"
ROUTER(config-applet)# action 1.2 cli command "interface Cellular0/2/0"
ROUTER(config-applet)# action 1.3 cli command "no shut"
Script 2
For this log:
Apr 25 11:17:49.881 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/2 is DOWN
ROUTER(config)#event manager applet cell2
ROUTER(config-applet)# event syslog pattern "Modem in HWIC slot 0/2 is DOWN"
ROUTER(config-applet)# action 1.1 cli cmmand "reload at 19:00"
5 ACCEPTED SOLUTIONS
These will work.  You can have them both configured at once.  However, the reload at is strange.  Is that the only way to recover?  Are you okay with waiting for a specific time to reload?
You could use a regexp to do this:
action 001 cli command "enable"
action 002 cli command "show clock"
action 003 regexp "([0-9]+):[0-9]:[0-9]" $_cli_result match hour
action 004 if $hour ge 17
action 005  reload
action 006 end
The regexp line extracts the hour portion of the time and the if lines compare that value to 17 (5pm) and 6 (6 am) respectively.  If the hour is greater than or equal to 17 or less than or equal to 6 (numerically) then the reload action will be invoked.
event manager applet mode-down
action 1.0 mail from user@company.com to user@company.com server 10.1.1.1 subject "Modem down" body "$_syslog_msg"
No.  Not given these scenarios.
event manager applet cell3
description "TEST ONLY"
event syslog pattern "Modem in HWIC slot 0/0 is DOWN"
action 0.5 set timed_reload 0
action 1.1 cli command "show clock"
action 1.2 regexp "([0-9]+):[0-9]+:[0-9]+" "$_cli_result" match hour
action 1.3 if $hour ge 18
action 1.4  reload
action 1.9 else
action 2.0  set timed_reload 1
action 2.1 end
action 2.2 if $hour lt 6
action 2.4  reload
action 2.8 else
action 2.9  set timed_reload 1
action 3.0 end
action 3.1 if $timed_reload eq 1
action 3.2  cli command "config t"
action 3.3  cli command "event manager applet reload-at-seven"
action 3.4  cli command "event timer cron cron-entry $q 0 19 * * *$q"
action 3.5  cli command "action 1.0 reload"
action 3.6  cli command "end"
action 3.7 end
It's the most convenient time to reload since our client business hours end at 17:00 or 5PM. So i don't want to put the connection down.
Is there as script that could identify when the time comes when the interface or HWIC modem will be down at 19:00 to 0600 and then reload it right away? So i don't have to wait 17:00.
action 005  reload
action 006 end
Wow, i'll try it and i'll let you know. Thanks so much on this. But is this right below?
ROUTER(config-applet)# action 1.1 cli command "show clock"
ROUTER(config-applet)# action 1.2 regexp "([0-9]+):[0-9]:[0-9]" $_cli_result match hour
ROUTER(config-applet)# action 1.3 if $hour ge 17
ROUTER(config-applet)# action 1.4 reload
ROUTER(config-applet)# action 1.5 end
Yes, but perhaps you want to do:
action 1.6 if $hour le 6
action 1.7  reload
action 1.8 end
And this will only work if the message comes in at that time.  It won't handle the case where the message comes in during business hours.  You would still want to add your reload at line in that case.
Sorry that i'm being persistent. I'm new at this.
Question, can you help me understand these scripts? the bold phrases.
ROUTER(config-applet)# action 1.6 if $hour le 6
ROUTER(config-applet)# action 1.7  reload
ROUTER(config-applet)# action 1.8 end
Appreciate it a lot!
Thank you so much for the assistance. Appreciate it!
hi joseph, i think the script is not working. i can't see any activity working based on the debug logs. thanks
Without seeing what you're seeing, I don't know what to tell you.  I'm honestly not even sure what the script looks like at this point.
here's what the script looks like
event manager session cli username "jvi01131990"
event syslog pattern "Interface Cellular0/0/0, changed state to down"
action 1.1 cli command "test cellular 0/0/0 modem-power-cycle"
action 1.3 if $hour ge 19
action 1.4  reload
action 1.5 end
action 1.7  reload
When one of these syslog messages is generated, what do you see in your debug output?  What does "show event manager history event" show?
to run cell1 manually, its successful, but not with cell2
PHILAM-COT-BR01#sh event manager history events
No.  Job Id Proc Status   Time of Event            Event Type         Name
1    1      Actv success  Mon Oct 7 13:12:01 2013  none               applet: cell1
CELL1
Oct  7 13:11:49.177 MNL: %SYS-5-CONFIG_I: Configured from console by jvi01131990 on vty0 (10.49.135.135)
Oct  7 13:12:01.293 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : CTL : cli_open called.
Oct  7 13:12:01.297 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : Reload scheduled for 20:00:00 MNL Mon Oct 7 2013 (in 6 hours and 47 minutes) by jvi01131
Oct  7 13:12:01.297 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : Reload reason: Reload Command
Oct  7 13:12:01.297 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : PHILAM-COT-BR01>
Oct  7 13:12:01.301 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : IN  : PHILAM-COT-BR01>enable
Oct  7 13:12:01.613 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : PHILAM-COT-BR01#
Oct  7 13:12:01.613 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : IN  : PHILAM-COT-BR01#test cellular 0/0/0 modem-power-cycle
Oct  7 13:12:10.925 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : Cellular
Modem in HWIC slot 0/0 is still in reset, we recommend to re-execute this cmd after 60 seconds
Oct  7 13:12:10.925 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : PHILAM-COT-BR01#
Oct  7 13:12:10.925 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : CTL : cli_close called.
CELL2
Oct  7 13:16:53.137 MNL: %HA_EM-6-FMPD_EEM_CONFIG: cell2: Missing "end" action in conditional block
Oct  7 13:16:53.137 MNL: %SYS-5-CONFIG_I: Configured from console by jvi01131990
Cell1 appears to be working.  In cell2, add:
action 1.8 end
That will take care of the error you see there.
On the underlined logs below, i can see now that the script is working on the 2 downtime instances but there's no indication that the reload command works.
Oct  7 09:09:33.086 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
Oct  7 09:09:49.674 MNL: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state
to reset
Oct  7 09:09:52.926 MNL: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/0 is now UP
Oct  7 09:09:54.674 MNL: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state
to down
Oct  7 09:10:14.718 MNL: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state
to up
Oct  8 08:29:28.113 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
ROUTER#sh event manager history events
1    1      Actv success  Mon Oct 7 09:09:33 2013  syslog             applet: cell2
2    2      Actv success  Tue Oct 8 08:29:28 2013  syslog             applet: cell2
Oct  8 09:14:14.948 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_open called.
Oct  8 09:14:14.952 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01>
Oct  8 09:14:14.952 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01>enable
Oct  8 09:14:15.264 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01#
Oct  8 09:14:15.264 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01#show clock
Oct  8 09:14:15.276 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : 09:14:15.264 MNL Tue Oct 8 2013
Oct  8 09:14:15.276 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01#
Oct  8 09:14:15.276 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_close called.
Also HWIC slot 0/0 keeps and always be down. How to prevent this?
Thank you so much.
The reload will only be invoked if the time is between 19:00 and 06:00.  The current time is 09:14.  So the router will not reload.  In terms of the HWIC, you don't do anything in your applet to bring it back up.  If there are commands that need to be run, add them to your cell2 applet.
is it still works even if it doesn't show up in sh logs? normally reload will take 3-5mins, but logs shows HWIC slot 0/0 is UP after a split second. (in bold)
to reset
to down
to up
I don't really understand what the flow from a hardware standpoint should be.  All I can tel you is what I see from the applet commands.  The cell1 applet runs the test command (what it should do, I don't know, but it is running).  The cell2 applet checks the time and reloads the whole router if the time is within a specific window.  That should work, too, if the time is right.
Sorry for being persistent, but for this scenario below, the HWIC did state it was down as of 00:05, but i think the applet didn't works, it supposed to reload between 19:00-6:00. So i reloaded it manually after i've noticed it at 8:43.
Oct  9 00:05:58.018 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
Oct  9 08:43:05.044 MNL: %SYS-5-SCHEDULED_RELOAD: Reload requested for 20:00:00 MNL Wed Oct 9 2013 at 08:43:03 MNL Wed Oct 9 2013 by jvi01131990 on vty0 (10.49.
135.135). Reload Reason: Reload Command.
Oct  9 08:46:47.592 MNL: %SYS-5-CONFIG_I: Configured from console by jvi01131990 on vty0 (10.49.135.135)
Oct  9 08:46:56.184 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_open called.
Oct  9 08:46:56.192 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : Reload scheduled for 20:00:00 MNL Wed Oct 9 2013 (in 11 hours and 13 minutes) by jvi0113
Oct  9 08:46:56.192 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : Reload reason: Reload Command
Oct  9 08:46:56.192 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01>
Oct  9 08:46:56.192 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01>enable
Oct  9 08:46:56.504 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01#
Oct  9 08:46:56.504 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01#show clock
Oct  9 08:46:56.516 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : 08:46:56.508 MNL Wed Oct 9 2013
Oct  9 08:46:56.516 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01#
Oct  9 08:46:56.516 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_close called.
Oct  9 08:48:40.104 MNL: %HA_EM-4-FMPD_NO_EVENT: No event configured for applet cell2
Oct  9 08:48:40.104 MNL: %SYS-5-CONFIG_I: Configured from console by jvi01131990 on vty0 (10.49.135.135)
This debug is from 08:46, though.  It doesn't show what happened at midnight.
I've noticed that the syslog below sometimes occur between 6AM - 6PM, so which means the event applet below will not take effect. question, how can i do a script that whenever the syslog pattern occur b/n 6AM-6PM i could set it up to reload automatically at 7PM. thanks
action 1.4 reload
action 1.5 end
action 1.7 reload
action 1.8 end
Have this applet configure another applet that triggers a reload at 19:00.  That is, add actions like:
event manager environment q "
action 1.7 cli command "config t"
action 1.8 cli command "event manager applet reload-at-seven"
action 1.9 cli command "event timer cron cron-entry $q 0 19 * * *$q"
action 2.0 cli command "action 1.0 reload"
action 2.1 cli command "end"
action 2.2 end
Same thing starting at action 1.4.
is this correct?
action 1.4 reload
action 1.5 end
action 1.7 reload
action 1.8 end
action 1.9 cli command "config t"
action 2.0 cli command "event manager applet reload-at-seven"
action 2.1 cli command "event timer cron cron-entry $q 0 19 * * *$q"
action 2.2 cli command "action 1.0 reload"
action 2.3 cli command "end"
action 2.4 end
No.  The action numbers I listed were what I meant.  Meaning what I provided was designed to replace action 1.7 on.  Note: you'll also have to replace actions 1.4 and 1.5 with the same list of items I did starting at action 1.7.
is this right?
the script must have this 2 scenario below. thanks.
  • 1st scenario should be it will reload automatically if syslog appears from 6PM to 6AM.
  • 2nd scenario should be it will reload at 7PM if syslog appears from 6AM to 6PM.
action 1.4 cli command "config t"
action 1.5 cli command "event manager applet reload-at-seven"
action 1.6 cli command "event timer cron cron-entry $q 0 19 * * *$q"
action 1.7 cli command "action 1.0 reload"
action 1.8 cli command "end"
action 1.9 end
action 2.0 if $hour le 6
action 2.1 cli command "config t"
action 2.2 cli command "event manager applet reload-at-seven"
action 2.3 cli command "event timer cron cron-entry $q 0 19 * * *$q"
action 2.4 cli command "action 1.0 reload"
action 2.5 cli command "end"
action 2.6 end
action 1.4  reload
action 1.9 else
action 2.1 end
action 2.4  reload
action 2.8 else
action 3.0 end
action 3.7 end
Hi Joseph, i've run the script and see if it works the way 2 scenarios should be. Thank you very much
Nov 12 15:19:04.828 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_open called.
Nov 12 15:19:04.828 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01>
Nov 12 15:19:04.828 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01>enable
Nov 12 15:19:05.140 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01#
Nov 12 15:19:05.140 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01#show clock
Nov 12 15:19:05.152 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : 15:19:05.140 MNL Tue Nov 12 2013
Nov 12 15:19:05.152 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01#
Nov 12 15:19:05.152 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01#config t
Nov 12 15:19:05.464 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : Enter configuration commands, one per line.  End with CNTL/Z.
Nov 12 15:19:05.464 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01(config)#
Nov 12 15:19:05.464 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : IN  : PHILAM-ANT-BR01(config)#event manager applet reload-at-seven
Nov 12 15:19:05.776 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : OUT : PHILAM-ANT-BR01(config-applet)#
Nov 12 15:19:05.776 MNL: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: q
Nov 12 15:19:05.776 MNL: %HA_EM-3-FMPD_ERROR: Error executing applet cell2 statement 3.4
Nov 12 15:19:05.776 MNL: %HA_EM-6-LOG: cell2 : DEBUG(cli_lib) : : CTL : cli_close called.
PHILAM-ANT-BR01#sh event manager history events
4    4      Actv success  Tue Nov12 15:19:04 2013  none               applet: cell2
You need to make sure the following is configured on your device:
5800
