Community Member
Monitor interface traffic
Hi Everyone,
Can i by using EEM (Embedded Event Manger) to monitor my interface traffic?
just to Clarification my question:
let's say if the traffic on interface gigabitEthernett0/0 less than 20Mbps the EEM will take an action.
thanks in advance.
1 ACCEPTED SOLUTION
Yes, this is doable with the
Yes, this is doable with the interface event detector.  You could do something like:
event interface name GigabitEthernet0/0 poll-interval 10 parameter transmit_rate_bps entry-val 20000000 entry-op lt entry-type value
Then perform actions when that event occurs.
Community Member
Hi Joe ,
Hi Joe ,
thank you i was checked it and it's working .
288
