Need Help with EEM script for monitoring Rx and Tx load on Link
I'm trying to implement a script, which monitors the Tx and Rx Load on the Link and sends a syslog in case the load is exceeded 200 mark (i.e If Rx or Tx load > 200)
I have implemented the following script. But it is not giving the required results.
event manager applet test
event interface name Tunnel111 parameter rxload entry-val 200 entry-op gt entry-val-is-increment true poll-interval 5000
action 1.0 syslog msg "Increase Load On the Link"
I'm trying to monitor the load on Tunnel 111 which is mapped to WAN interface.
Router (Cisco 2821) has following IOS
c2800nm-advipservicesk9-mz.124-25g.bin
Everyone's tags (2)
1 ACCEPTED SOLUTION
The values for txload and rxload are not incremental.  Remove entry-val-is-increment.  Also, your polling interval is 8.33 minutes.  Is that what you want?
Hello Joseph,
As per your suggestion, we made some changes in our script and the following script is working fine. Its giving the required syslogs when the load is exceeded.
event interface name Tunnel111 parameter txload entry-val 200 entry-op gt entry-val-is-increment false poll-interval 5
action 1.0 syslog msg "Increased Load On the Link"
Your prompt assistance is really appriciated.
686
