Problem with EEM for monitoring CPU high on C4506
I have a C4506 running cat4500e-universal.SPA.03.02.05.SG.150-2.SG5.bin.
It dont have AAA configuration. It has the following one:
username cisco14 privilege 14 secret cisco14
username cisco5 privilege 5 secret cisco5
privilege exec level 10 enable
event manager session cli username "cisco14"
event manager applet test
event snmp oid cpmCPUTotal1minRev.1000 get-type exact entry-op ge entry-val "5" poll-interval 5
action 0.0 syslog priority errors msg "High CPU DETECTED $_snmp_oid_val"
action 0.1 cli command "enable"
action 0.2 cli command "term exec prompt timestamp"
action 1.2 cli command "term length 0"
action 1.3 cli command "show process cpu sorted | append bootflash:cpuinfo.txt"
action 1.4 cli command "show process cpu history | append bootflash:cpuinfo.txt"
action 2.1 cli command "show log | append bootflash:cpuinfo.txt"
action 2.2 cli command "term length 24"
My problem is that EEM failed at "enable" then the applet won't execute the CLI commands when the EEM applet is triggered:
debug event manager action cli
Feb 13 11:03:55.508 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT :
Feb 13 11:03:55.508 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : CTL : 20+ lines read from cli, debug output truncated
Feb 13 11:03:55.508 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>enable
Feb 13 11:04:04.548 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : Translating "enable"...domain server (255.255.255.255)
Feb 13 11:04:04.548 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : % Unknown command or computer name, or unable to find computer address
Feb 13 11:04:04.548 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 13 11:04:04.548 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>term exec prompt timestamp
Feb 13 11:04:04.670 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 13 11:04:04.670 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>term length 0
Feb 13 11:04:04.782 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 13 11:04:04.782 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>show process cpu sorted | append bootflash:cpuinfo.txt
Feb 13 11:04:04.894 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : ^
Feb 13 11:04:04.894 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Feb 13 11:04:04.895 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT :
Feb 13 11:04:04.895 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 13 11:04:04.895 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>show process cpu history | append bootflash:cpuinfo.txt
Feb 13 11:04:05.007 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : ^
Feb 13 11:04:05.007 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Feb 13 11:04:05.007 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 13 11:04:05.007 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>show log | append bootflash:cpuinfo.txt
Feb 13 11:04:05.118 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : ^
Feb 13 11:04:05.118 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Feb 13 11:04:05.119 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT :
Feb 13 11:04:05.119 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 13 11:04:05.119 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>term length 24
Feb 13 11:04:05.131 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 13 11:04:05.131 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : CTL : cli_close called.
Please help me to resolve this problem
VIP Purple
What privilege level do you
What privilege level do you have on the 4500 when your logged in ? show privilege
It could be that blocking you from using eem , if you have priv 15 it could be something else , but the script looks ok
Hi mark malone,
Hi mark malone,
User Access Verification
Username: cisco14
Password:
SWITCH#show pri
SWITCH#show privilege
Current privilege level is 14
SWITCH#enable
Password:
SWITCH#
Current privilege level is 15
I found that when i configured the "privilege exec level 1 enable" command, it is ok:
But due to my company policy, if i config "privilege exec level 10 enable", what can i config next step ?
Feb 13 11:06:42.790 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : CTL : 20+ lines read from cli, debug output truncated
Feb 13 11:06:42.790 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH>enable
Feb 13 11:06:42.792 Hanoi: %PARSER-5-CFGLOG_LOGGEDCMD: User:cisco14 logged command:!exec: enable
Feb 13 11:06:42.803 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH#
Feb 13 11:06:42.803 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH#term exec prompt timestamp
Feb 13 11:06:42.814 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH#
Feb 13 11:06:42.814 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH#term length 0
Feb 13 11:06:42.827 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT : SWITCH#
Feb 13 11:06:42.827 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : IN : SWITCH#show process cpu sorted | append bootflash:cpuinfo.txt
Feb 13 11:06:43.317 Hanoi: %HA_EM-6-LOG: test : DEBUG(cli_lib) : : OUT :
VIP Purple
Hi you could Try set yourself
Hi you could Try set yourself as priv 10 as that's what's allowed to run the enable_____ username yourname secret xxx priv 10 or try in your eem script enable 10
With "privilege exec level 10 enable"
i set three different cases for the below example, i run manual EEM by the "event manager run test1" command but the result is still not better:
username cisco10 privilege 10 secret cisco10
event manager session cli username cisco10
event manager applet test1
event none
event none
action 0.1 cli command "enable 10"
event manager session cli username cisco14
event none
Feb 15 09:47:40.685 Hanoi: %HA_EM-6-LOG: test1 : DEBUG(cli_lib) : : CTL : 20+ lines read from cli, debug output truncated
Feb 15 09:47:40.685 Hanoi: %HA_EM-6-LOG: test1 : DEBUG(cli_lib) : : IN : SWITCH>enable 10
Feb 15 09:47:40.896 Hanoi: %HA_EM-6-LOG: test1 : DEBUG(cli_lib) : : OUT : Translating "enable"...domain server (255.255.255.255)
Feb 15 09:47:40.896 Hanoi: %HA_EM-6-LOG: test1 : DEBUG(cli_lib) : : OUT : % Unknown command or computer name, or unable to find computer address
Feb 15 09:47:40.896 Hanoi: %HA_EM-6-LOG: test1 : DEBUG(cli_lib) : : OUT : SWITCH>
Feb 15 09:47:40.896 Hanoi: %HA_EM-6-LOG: test1 : DEBUG(cli_lib) : : CTL : cli_close called.
Feb 15 09:47:40.896 Hanoi: tty is now going through its death sequence
Hi mark malone and anyone,
can you give me an advice for this case ?
VIP Purple
Hi really need to lab this to
Hi really need to lab this to see whats happening have not had a chance but you can try this in your config
enable password level 10 (password)
Hi mark malone,
Hi mark malone,
i tried but it is not better than before.
I think that at the User EXEC Mode of EEM, Switch> is default level 1
if we set "privilege exec level 10 enable" command so EEM can not enter "enable " at the User EXEC Mode of its.
I think we should set the "privilege exec level 1 enable" or " no privilege exec level 10 enable" command
If you finish your lab on this case, please let me know your result.
VIP Purple
If you get rid of the priv 10
If you get rid of the priv 10 it will work I thought though you had to have there for company policy so I was trying to work out to get around it :) , im still going to lab it over the weekend when im free to see either way as there has to be a way to get it working even with that there.
Hi, thank you for your time
Hi, thank you for your time on this matter.
I will look forward to your result.
139
