Script Active Even Though Unregistered
Hello Community,
I have situation where a script called netc.tcl is active but doesn't actually exists i.e. not registered.
MX-IPS1#show even manager policy active
Key: p - Priority        :L - Low, H - High, N - Normal, Z - Last
     s - Scheduling node :A - Active, S - Standby
default class - 1 script event
no.  job id      p s status  time of event             event type          name
1    541285      N A running Tue Jul30 12:31:22 2013   none                netc.tcl
Can someone please show me how to remove it
Below is a list of scripts currently registered:
MX-IPS1#show run | inc event
event manager directory user policy "flash:/"
event manager scheduler script thread class Z number 5
event manager policy stateInterfacestatus.tcl
event manager policy utilisationHighInterfaceUtilization.tcl
event manager policy cpuHighCPUUsage.tcl
event manager policy memoryHighMemory.tcl
event manager policy configCONFCHG.tcl
event manager policy envAssetChassisIssue.tcl
event manager policy syslogOSPF.tcl
event manager policy syslogIPNAT.tcl
event manager policy syslogIOSVLAN.tcl
MX-IPS1#show eve m p r
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    script    user    timer watchdog      Off   Sun Aug 25 18:54:37 2013  stateInterfacestatus.tcl
name {stateInterfacestatus} time 60.000
nice 1 queue-priority low maxrun 20.000 scheduler rp_primary
2    script    user    timer watchdog      Off   Sun Aug 25 18:54:37 2013  utilisationHighInterfaceUtilization.tcl
name {utilisationHighInterfaceUtilizat} time 60.000
nice 1 queue-priority low maxrun 60.000 scheduler rp_primary
3    script    user    timer watchdog      Off   Sun Aug 25 18:54:37 2013  cpuHighCPUUsage.tcl
name {cpuHighCPUUsage} time 60.000
4    script    user    timer watchdog      Off   Sun Aug 25 18:54:37 2013  memoryHighMemory.tcl
name {memoryHighMemory} time 60.000
5    script    user    syslog              Off   Sun Aug 25 18:54:37 2013  configCONFCHG.tcl
occurs 1 pattern {SYS-5-CONFIG_I.*}
nice 0 queue-priority normal maxrun 20.000 scheduler rp_primary
6    script    user    syslog              Off   Sun Aug 25 18:54:38 2013  envAssetChassisIssue.tcl
severity-warning severity-minor severity-major severity-critical severity-fatal occurs 1 pattern {ENV.*}
nice 0 queue-priority normal maxrun 60.000 scheduler rp_primary
7    script    user    syslog              Off   Sun Aug 25 18:54:38 2013  syslogOSPF.tcl
priority all pattern {OSPF}
8    script    user    syslog              Off   Sun Aug 25 18:54:38 2013  syslogIPNAT.tcl
priority all pattern {IPNAT}
As you can see netc.tcl isn't actually registered but still active.
Thanks in advance for your help.
Cheers
  • EEM Scripting
Try "event manager scheduler clear all".  If that doesn't work, you'll need to reload.
Hi Carlton,
I'm sorry, what version of code is this?  This should not be possible in the latest versions of EEM 2.4 and later.  I committed the fix to prevent this via CSCso98512 - Running EEM scripts should be terminated when removed from the config.  After this change, when the policy is unregistered it should be forcibly killed similar to how the maxrun timer kills a policy.
Mike
The code was changed again to allow policies to continue to run because of the common use case of unregistering the policy from itself then doing some other cleanup.  So in very new versions of code, this behavior is expected.  Though it should be killable with the scheduler clear command.
Hello all,
Thanks ever-so-much for getting to me.
I have tried clearing the script with "event manager scheduler clear all" but to no avail.
The versions are as follows:
MX-IPS1#show version
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 20-Oct-09 01:15 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH6, RELEASE SOFTWARE (fc1)
MX-IPS1 uptime is 17 weeks, 6 days, 1 hour, 44 minutes
System returned to ROM by Reload Command
System restarted at 19:31:27 UTC Wed Apr 24 2013
System image file is "flash:c181x-advipservicesk9-mz.124-24.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1812 (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FCZ1101109R, with hardware revision 0000
10 FastEthernet interfaces
1 ISDN Basic Rate interface
31360K bytes of ATA CompactFlash (Read/Write)
X-IPS1#show event manager version
Embedded Event Manager Version 3.00
Component Versions:
eem: (v300_throttle)2.2.2
eem-gold: (v300_throttle)1.0.10
eem-call-home: (v300_throttle)2.0.2
Event Detectors:
Name                Version   Node        Type
appl                01.00     node0/0     RP
syslog              01.00     node0/0     RP
resource            01.00     node0/0     RP
routing             01.00     node0/0     RP
track               01.00     node0/0     RP
cli                 01.00     node0/0     RP
counter             01.00     node0/0     RP
gold                01.00     node0/0     RP
interface           01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
ipsla               01.00     node0/0     RP
none                01.00     node0/0     RP
nf                  01.00     node0/0     RP
oir                 01.00     node0/0     RP
snmp                01.00     node0/0     RP
snmp-notification   01.00     node0/0     RP
timer               01.00     node0/0     RP
test                01.00     node0/0     RP
config              01.00     node0/0     RP
env                 01.00     node0/0     RP
rpc                 01.00     node0/0     RP
MX-IPS1#
If you can think of any other suggestion other than reloading the router I would be truly grateful.
Carlton
You should see the policy terminate on unregistering it in this release.  However, I have seen cases where this did not work if the policy enters a blocking state.  One way that can happen is reading from a socket.  In these cases, the only way to remove the policy was to reload.  Even a maxrun expiration wouldn't work since the policy is blocked.  If it were to try and execute another instruction, it would terminate, but since it won't, then it never terminates.
606
