Script to inspect files in flash and create two sequential entries
What im trying to do:
1. Have the switch do a showtech every 2 hours
2. Send the showtech to flash
3. The first showtech will be techinfo1.txt
4. The second will be techinfo2.txt
5. The next showtech will overwrite techinfo1.txt
6. The next showtech will overwrite techinfo2.txt and so forth.
Is this possible? In the direction of regexpressions possibly?
Write now I have it appending to flash in one file and than once it hits a certain file size, clearing the file and restarting it. I don't like doing it like that.
::cisco::eem::event_register_timer cron name tech1 cron_entry 0 */2 ***
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
set x = file size flash:techinfo.txt
if {$x > 5242880}
file delete flash:techinfo.txt
else{
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_exec $cli1(fd) "show tech-support | append flash:techinfo.txt"} _cli_result] {
catch {cli_close $cli1(fd) $cli1(tty_id)} result
Credit to Joseph Clark for the applet converter
9 ACCEPTED SOLUTIONS
You can use file mtime for this:
set filename "flash:techinfo2.txt"
set now [clock seconds]
if { [file exists $filename] && [expr $now - [file mtime $filename]] < 14400 } {
    set filename "flash:techinfo1.txt"
# Send your output to $filename
Your whole script is in a function that you never call.  Just remove the lines:
proc get_tech {} {
And the last '}' in the file.
EEM Safe Tcl blocks the mtime command.  Try adding this line above the mtime line:
array set stat [file stat $filename]
Then change the mtime check to:
[expr $now - $stat(mtime)] < 14400
You still have that array set line in there.  Do this.  Replace the line starting with "array set" with these lines:
if { [file exists $filename] } {
    file stat $filename sarr
    if { [expr $now - $sarr(mtime)] < 14400 } {
        set filename "newtech.txt"
You first have to make sure you set filename appropriately before you send the output of show tech to it.  I'm not sure you're doing that in your current script.  Then for rotation, this should work:
set filename "flash:tech1.txt"
set nfilename "flash:text2.txt"
    cli_exec $cli(fd) "copy $filename $nfilename"
cli_exec $cli(fd) "show tech | redirect $filename"
If the policy is already running every two hours, flash:tech1.txt will contain the latest stuff, and flash:tech2.txt will contain the previous run.
This line:
cli_exec $cli1(fd) "show tech | redirect $filename" _cli_result
Should be:
Or:
if { [catch {cli_exec $cli1(fd) "show tech | redirect $filename"} _cli_result] } {
You'll also need to set file prompt quiet to remove the prompting:
    cli_exec $cli1(fd) "config t"
    cli_exec $cli1(fd) "file prompt quiet"
    cli_exec $cli1(fd) "do copy $filename $nfilename"
    cli_exec $cli1(fd) "no file prompt quiet"
    cli_exec $cli1(fd) "end"
The file prompt quiet suppresses the prompt, and thus the timeout problem should go away (unless, of course, it takes more than 20 seconds to generate the show tech).  If you still need more time, you'll need to add a maxrun argument to the end of your event registration line (e.g., maxrun 60).
Weird.  The "do" copy worked in my test.  Okay, change your if block to this:
    cli_exec $cli1(fd) "copy $filename $nfilename"
Re: Script to inspect files in flash and create two sequential e
The redirect is likely triggering another prompt.  After the copy, add:
cli_exec $cli1(fd) "delete /force $filename"
Thanks for your response Joe.
Right now this is what I have. I will be using an applet countdown to trigger it but for now I am trying to run it manually.
Below is the script. When I run it I am not getting any file created in flash.
::cisco::eem::event_register_none
#Namespace Imports
proc get_tech {} {
#Set Variable Filename
set filename "flash:oldtech.txt"
#set timer in seconds allowing it to be used for relative time calculations
#Send Showtech Output to Flash Filename Variable
if [catch {cli_exec $cli1(fd) "show tech-support | flash:$filename"} _cli_result] {
} else {
#Determine File Name Through Age Comparison
    set filename "flash:newtech.txt"
I turned on logging and this is what I get:
Switch#event manager run showtech.tcl
Switch#
*Dec  9 10:44:36.737: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Dec  9 10:44:36.737: check_eem_cli_policy_handler: command_string=event manager run showtech.tcl
*Dec  9 10:44:36.737: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
*Dec  9 10:44:36.737: fh_fd_none_event_match: parameters = , sync = 1, get_tty = 1, tty_buf = 0
*Dec  9 10:44:36.737: none_conn_tm_alloc: ptp=0x3A4FF4D4
*Dec  9 10:44:36.737: fh_fd_none_event_match: publish_timer=0x349E7480, ptp=0x3A
Switch#4FF4D4, max_delay=30000
*Dec  9 10:44:36.737: none_conn_tm_add: re=0x3A500854, ptp=0x3A4FF4D4
*Dec  9 10:44:36.737: fh_fd_none_event_match: re = 0x3A500854, num_matches = 1
*Dec  9 10:44:36.737: fh_send_server_sig_hndlr: received a pulse from none on node0/0 with fdid: 11
*Dec  9 10:44:36.737: fh_send_none_fd_msg: msg_type=64
*Dec  9 10:44:36.737: fh_send_none_fd_msg: sval=0
*Dec  9 10:44:36.737: fh_send_server_sig_hndlr: received FH_MSG_EVENT_PUBLISH_SYNC
*Dec  9 10:44:36.737: EEM: server processe
Switch#s multi events: timewin=1, sync_flag=1, ec_index=0, cmp_occ=1
*Dec  9 10:44:36.737: EEM: ctx=5:(5,1,1)
*Dec  9 10:44:36.737: EEM: server processes multi events: corr_res=1, cur_tcnt=1, cmp_tcnt=1
*Dec  9 10:44:36.737: fh_schedule_policy: prev_epc=0x0; epc=0x3A48397C
*Dec  9 10:44:36.737: EEM server schedules scripts
*Dec  9 10:44:36.737: EEM server schedules one event: policy_type=script epc=3A48397C.
*Dec  9 10:44:36.737: EEM: server schedules a policy: policyname=tmpsys:/eem_policy/showtech.tcl
*D
Switch#ec  9 10:44:36.738: spawn script tmpsys:/eem_policy/showtech.tcl
*Dec  9 10:44:36.738: EEM policy tmpsys:/eem_policy/showtech.tcl has been scheduled to run
*Dec  9 10:44:36.738: fh_spawn: -FMRUN -FMSAFE tmpsys:/lib/tcl/base.tcl tmpsys:/eem_policy/showtech.tcl
*Dec  9 10:44:36.738: fh_tcl_spawn: argc=5, argstr=-FMRUN, stdin=0, stdout=0,stderr=0, priority=4, eid=5
*Dec  9 10:44:36.738: pid for spawned process is 224. fdid: 11 sn: 4 jobid: 7
*Dec  9 10:44:36.739: fh_tcl_get_mode: mode = 1, StartupScript
Switch#= tmpsys:/lib/tcl/base.tcl, RealScript = tmpsys:/eem_policy/showtech.tcl
*Dec  9 10:44:36.739: fh_set_tclpath_global: tcl_library is set to tmpsys:/lib/tcl
*Dec  9 10:44:36.739: fh_set_tclpath_global: auto_path is set to tmpsys:/eem_lib_user tmpsys:/eem_lib_system
*Dec  9 10:44:36.747: fh_io_msg: received FH_MSG_API_INIT; jobid=22, processid=224, client=12, job name=EEM TCL Proc
*Dec  9 10:44:36.747: fh_register_evreg_cmds: tctx=35173CE4, dummy=1
*Dec  9 10:44:36.748: fh_tcl_compile_policy: evaluating
Switch# policy: startup_scriptname=tmpsys:/lib/tcl/base.tcl, real_scriptname=tmpsys:/eem_policy/showtech.tcl
*Dec  9 10:44:36.749: fh_tcl_slave_interp_init: interp=3A2FE728, tctx=35173CE4, fh_mode=1, real=tmpsys:/eem_policy/showtech.tcl, curr=showtech.tcl
*Dec  9 10:44:36.754: fh_register_evreg_cmds: tctx=35173CE4, dummy=1
*Dec  9 10:44:36.995: fh_server: fh_io_msg: received msg FH_MSG_API_CLOSE from client 12 pclient 12
*Dec  9 10:44:36.995: fh_io_msg: received FH_MSG_API_CLOSE client=12
*Dec  9 10:44:36.99
Switch#6: fh_tcl_assoc_data_delproc: freeing tctx=0x35173CE4
*Dec  9 10:44:37.010: received SIGCHLD pulse from child death pid=224
*Dec  9 10:44:37.010: received pulse from child death code=1; epc=0x3A48397C
*Dec  9 10:44:37.010: EEM policy showtech.tcl has completed with normal exit status of 0x0 exec_status=2 event_completion=0
*Dec  9 10:44:37.010: fh_send_none_fd_msg: msg_type=18
*Dec  9 10:44:37.010: fh_fd_none_publish_done: rc=0, re=3A500854
*Dec  9 10:44:37.010: fh_fd_none_publish_done: rc=0, publish
Switch#_expired=0
*Dec  9 10:44:37.010:   sid=5, ptp=0x3A4FF4D4, connp=0x3A3B34C8
*Dec  9 10:44:37.010: none_conn_tm_remove: re=0x3A500854, ptp=0x3A4FF4D4
*Dec  9 10:44:37.010: fh_fd_none_conn_tm_free: ptp=0x3A4FF4D4
*Dec  9 10:44:37.010: fh_send_none_fd_msg: sval=0
*Dec  9 10:44:37.010: EEM: server decrements in use thread: jobid=7 rule id=1 in use thread=0.
*Dec  9 10:44:37.010: fh_schedule_policy: prev_epc=0x3A48397C; epc=0x0
*Dec  9 10:44:37.010: EEM server schedules scripts
Switch#server schedules sync same source events:fdid=11; sn=4.
*Dec  9 10:44:37.010: fh_fd_match_event: re=0x3A500854, policyname=showtech.tcl, parameters=, get_tty=1
proc get_tech {} {
The script has been working
The script has been working as it should be it fills the bootflash with the deleted files which makes sense.
I modified the CLI section of the script to squeeze the bootflash but now it is not working.
I turned on debugging for all event manager and im not seeing any output at all
This is the CLI portion with changes:
if { [file exists $filename] } {delete
    cli_exec $cli1(fd) "delete /force $nfilename"
    cli_exec $cli1(fd) "squeeze bootflash:"
Does it look off to anyone?
First, run all of these
First, run all of these commands manually to see what prompts you may get.  If you're getting any prompts, you will need to handle them.  Next, squeeze can take a few seconds, so you may need to increase your maxrun time for this policy to something like 45 or 60 seconds.
Yes, i did that and noticed
Yes, i did that and noticed that squeeze bootflash prompts twice
All deleted files will be removed. Continue? [confirm]
Squeeze operation may take a while. Continue? [confirm]
That's why I nested it in the CLI commands while the fileprompt quiet was still on. and then shut the file prompt after.
The runtime I had also increased previously.
Thanks for the quick reply
So if you run ALL of the
So if you run ALL of the commands including file prompt quiet, and the prompting still occurs, then you need to use cli_write to send the squeeze command and cli_read_pattern to wait for the prompt.  When you get the prompt, use cli_write again to send the appropriate response.  You can use cli_exec again when you are sure the result will be the router prompt.
Thanks,When I manually run
When I manually run the script using cli command "event manager run showtech.tcl" , nothing at all is happening.
I turned on "debug event manager tcl cli" and then ran the script again.. no output in terminal.
I then turned on all event manager debuging and ran the script..still no output.
This is the script:
::cisco::eem::event_register_none maxrun 2200
#Namespace Imports
#Pass CLI Commands
} else {
#Set Variables
set nfilename "flash:oldtech.txt"
#Copy New File to Old at Next Instance
    cli_write $cli1(fd) "squeeze bootflash:"
    cli_read_pattern $cli1(fd) "confirm"
    cli_write $cli1(fd) "confirm"
#Pipe Show-Technology to Set Variable
Sounds to me like either you
Sounds to me like either you didn't enable "term mon" or you are not logging at debug level to the monitor output.  Make sure you have the following configured:
logging monitor debug
Then make sure you run "term mon" on your VTY.  If you do that, you should see some output from the debugs when you run the policy.
Thanks. I've been debugging and testing and am hung up on this:
not allowed to invoke subcommand mtime of file
    while executing
"error $msg"
    (procedure "::safe::Subset" line 46)
    invoked from within
"file mtime $filename"
    invoked from within
"$slave eval $Contents"
    (procedure "eval_script" line 7)
    invoked from within
"eval_script slave $scriptname"
    invoked from within
"if {$security_level == 1} {       #untrusted script
     interp create -safe slave
     interp share {} stdin slave
     interp share {} stdout slave
    (file "tmpsys:/lib/tcl/base.tcl" line 50)
Tcl policy execute failed: not allowed to invoke subcommand mtime of file
This is how the script currently looks:
#Namespace Imports
#Pass CLI Commands
} else {
set filename "oldtech.txt"
if [catch {cli_exec $cli1(fd) "show tech-support | redirect flash:$filename"} _cli_result] {
That was correct.
Thanks for the help thus far.
The array set stat should be [file state filename VARname]
For the file name I first tried mtime because the script appeared to want it in the arguments.
That was not correct because it wants a directory or file to check which makes sense.
I then tested it with oldtech.txt. This seems to be in the correct direction.
It's complaining about the mtime in the arguments array again.
Any ideas?
can't read "stat(mtime)": no such element in array
    while executing
"expr $now - $stat(mtime)"
    invoked from within
    invoked from within
    invoked from within
Tcl policy execute failed: can't read "stat(mtime)": no such element in array
Here's where I am at:
array set stat [file stat oldtech.txt $filename]
if { [file exists $filename] && [expr $now - $stat(mtime)] < 14400 } {
I confused Perl and Tcl behavior.  Perl returns the array, but Tcl allows you to fetch one stat parameter at a time.  So you want:
[expr $now - [file stat $filename mtime]]
Thanks Joe.
I am still having the arguments error that I encountered troubleshooting earlier.
wrong # args: should be "file stat name varName"
    while invoking
"file stat oldtech.txt"
    invoked from within
"::interp invokehidden slave file stat oldtech.txt"
    ("eval" body line 1)
    invoked from within
"eval ::interp invokehidden $slave $command $subcommand [lrange $args 1 end"
    (procedure "::safe::Subset" line 42)
    invoked from within
"file stat $filename"
    invoked from within
    invoked from within
    invoked from within
Tcl policy execute failed: wrong # args: should be "file stat name varName"
Current script from switch
Switch#show event manager policy registered detailed showtech.tcl
#Namespace Imports
#Pass CLI Commands
} else {
if { [file exists $filename] && [expr $now - [file stat $filename mtime]]
< 14400 } {
Thanks, everything was correct.
I need to re-evaluate this because how I am using mtime the oldtech.txt will never be overwritten or updated.
Is there any kind of FIFO that can be implemented with TCL with a queue size of two?
I just need two showtechs to go into the flash and the oldest one always overwritten. I have a seperate applet triggering the EEM policy to run every two hours.
Yes great thanks, I was reading about the copy command. And incase the text2.txt file keeps appending I believe force copy can be used to overwrite it.
Initially I thought to send the showtech output to flash first which is why I redirected it there. I see that the variables should be the ones piping it to flash.
After some small adjustments it's timing out due to the $result variable. I thought this might be because result isnt being called back after the showtech runs.
I tried appending it to the showtech redirect line in the format "_cli_result" but receive the same error.
Policy
#Pass CLI Commands
} else {
set nfilename "flash:newtech.txt"
Error
Process Forced Exit- MAXRUN timer expired.
    while executing
"return -code error "error reading the channel: $result""
    (procedure "cli_exec" line 5)
    invoked from within
"cli_exec $cli1(fd) "copy $filename $nfilename""
    invoked from within
    invoked from within
    invoked from within
Tcl policy execute failed: Process Forced Exit- MAXRUN timer expired.
This line:
Should be:
Or:
Good tip with file prompt quiet so it doesn't ask for confirmation.
In my previous post i had already tried it the correct ways you posted so I am still at the same error as last post.
I had a stray bracket and the maxrun timer was too short as you suggested.
Do you see any issue with the current script below?
Its succesfully creating one showtech instance (oldtech.txt) and any time the script runs again it does not overwrite oldtech.txt and it does not create newtech.txt.
Essentially the "if" statement is being ignored.
I turned on all debugging and there are no errors when i run it.
::cisco::eem::event_register_none maxrun 900
#Namespace Imports
#Pass CLI Commands
} else {
Post the output of "debug event manager tcl cli" when this policy runs.
There was a heavy delay, my bad.
*Jan  6 12:47:13.990: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch#
*Jan  6 12:47:13.991: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : CTL : cli_close called.
*Jan  6 12:47:14.273: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : CTL : cli_open called.
*Jan  6 12:47:14.406: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch>
*Jan  6 12:47:14.407: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : IN  : Switch>enable
*Ja
--More-- n  6 12:47:14.616: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch#
*Jan  6 12:47:14.619: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : IN  : Switch#config t
*Jan  6 12:47:14.855: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Enter configuration commands, one per line.  End with CNTL/Z.
*Jan  6 12:47:14.855: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch(config)#
*Jan  6 12:47:14.855: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : IN  : Switch(config)#file prompt quiet
*Ja
--More-- n  6 12:47:15.063: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch(config)#
*Jan  6 12:47:15.063: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : IN  : Switch(config)#do copy flash:oldtech.txt flash:newtech.txt
*Jan  6 12:47:15.375: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : copy not allowed in config mode or submode
*Jan  6 12:47:15.375: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch(config)#
*J
--More-- an  6 12:47:15.375: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : IN  : Switch(config)#no file prompt quiet
*Jan  6 12:47:15.587: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch(config)#
*Jan  6 12:47:15.587: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : IN  : Switch(config)#end
*Jan  6 12:47:15.595: %SYS-5-CONFIG_I: Configured from console by  on vty0 (EEM:showtech.tcl)
*Jan  6 12:47:15.694: %HA_EM-6-LOG: showtech.tcl : DEBUG(cli_lib) : OUT : Switch#
--More-- wtech.tcl : DEBUG(cli_lib) : IN  : Switch#show tech | redirect flash:oldtech.txt
Thanks, it's very close now. I'm still having an issue that I've been trying to debug the last few days.
The oldtech and newtech are initially being created but the next time and every other time after that the oldtech does not get updated, just the newtech.
For Example:
The current script:
#Namespace Imports
#Pass CLI Commands
} else {
The Flash:
11     809388 Jan 08 2014 13:34:28 +00:00 oldtech.txt
12     809388 Jan 10 2014 07:01:04 +00:00 newtech.txt
The debugging
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: Process Forced Exit- MAXRUN timer expired.
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:     while executing
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: "if [catch {cli_read $fd} result] {
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:         return -code error "error reading the channel: $result"
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:     } else {
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:         return $result
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:     }"
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:     (procedure "cli_exec" line 4)
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:     invoked from within
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: "cli_exec $cli1(fd) "show tech | redirect $filename" "
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: "$slave eval $Contents"
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:     (procedure "eval_script" line 7)
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: "eval_script slave $scriptname"
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: "if {$security_level == 1} {       #untrusted script
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:      interp create -safe slave
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:      interp share {} stdin slave
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:      interp share {} stdout slave
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: ..."
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl:     (file "tmpsys:/lib/tcl/base.tcl" line 50)
*Jan 10 06:58:18.409: %HA_EM-6-LOG: showtech.tcl: Tcl policy execute failed:
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    applet    user    timer countdown     Off   Fri Jan 10 06:04:58 2014  techtimer
time 1000.000
maxrun 20.000
action 1.0 policy showtech.tcl
2    script    user    none                Off   Fri Jan 10 06:18:30 2014  showtech.tcl
policyname {showtech.tcl} sync {yes}
nice 0 queue-priority normal maxrun 2200.000 scheduler rp_primary Secu none
I know from the debugging that the maxrun is still timing out but I don't beleive it is because of the length of the showtech. I timed the showtech at 16 minutes and set the maxrun timer to double that.
There must be another prompt that is thrown even though file prompt quiet is configured.  Try adding a "delete /force" command before you do the copy:
   Same thing Joe, the newtech updates but the oldtech does not.
Can you post the new script as well as the "debug event manager tcl cli" output again?
1652
