Smartport - 1142 and 3502
Does Smartport support the 1142 AP and the 3502 AP?  It keeps comming up as a Router device - CISCO_ROUTER_EVENT
The 1131 AP work fine.
Hall of Fame Super Gold
You need to explain a bit more.
Using the Smartport built-in macros:
macro auto execute CISCO_WIRELESS_LIGHTWEIGHT_AP_EVENT
macro auto execute CISCO_WIRELESS_AP_EVENT
macro auto execute CISCO_ROUTER_EVENT
When we plug in a 1142 AP, the port is assigned to the correct vlan (240) and the macro description shows "CISCO_WIRELESS_LIGHTWEIGHT_AP_EVENT"
When we plug in a 3502 AP, the port is not assigned to the correct vlan (176) and the macro description shows "CISCO_ROUTER_EVENT"
Here are the macros:
macro auto execute CISCO_WIRELESS_LIGHTWEIGHT_AP_EVENT  {
    if [[ $LINKUP -eq YES ]]; then
        conf t
            interface  $INTERFACE
                macro description $TRIGGER
                switchport access vlan 240
                switchport mode access
                spanning-tree portfast
            exit
        end
    fi
    if [[ $LINKUP -eq NO ]]; then
        conf t
                no macro description
                no switchport access vlan 240
                no spanning-tree portfast
                if [[ $AUTH_ENABLED -eq NO ]]; then
                    no switchport mode access
                fi
            exit
        end
    fi
        conf t
                switchport access vlan 176
            exit
        end
    fi
        conf t
                no switchport access vlan 176
                fi
            exit
        end
    fi
Macro auto execute CISCO_ROUTER_EVENT  {
        conf t
                switchport access vlan $ACCESS_VLAN
            exit
        end
    fi
        conf t
                no switchport access vlan $ACCESS_VLAN
                fi
            exit
        end
    fi
Move this thread to the EEM section.
If Joe Clark is not busy, he should be able to help you.
ok, how do I move the thread?
Upper right-hand corner, under "Action".
The CDP platform needs to be AIR-LAP for it to fire that macro.  Perhaps these APs identify themselves differently...
So what macro trigger do I use?
Here is what is available by typing the command - macro auto execute ?
CISCO_CUSTOM_EVENT
CISCO_DMP_EVENT
CISCO_IPVSC_EVENT
CISCO_LAST_RESORT_EVENT
CISCO_PHONE_EVENT
CISCO_ROUTER_EVENT
CISCO_SWITCH_EVENT
You may have to define your own trigger and a custom profile.  What is the platform advertised by this AP?
AIR-LAP1131AG-A-K9 - this one works (CISCO_WIRELESS_LIGHTWEIGHT_AP_EVENT)
AIR-LAP1142N-A-K9 - this one does not work
AIR-CAO3502I-A-K9 - this one does not work
But what do you see in show cdp neighbor for these APs?
I typed the 3502 wrong is should be AIR-CAP3402I-A-K9
This is what I see as the platform (above) when I run "sh cdp n d".  If I just type "sh cdp n" I see:
AIR-LAP11 for the AIR-LAP1131AG-A-K9
AIR-LAP11 for the AIR-LAP1142N-A-K9
AIR-CAP35 for the AIR-CAP3502I-A-K9
Okay, this is bug CSCtk00846, and it should be fixed in 12.2(55)SE4 (on the switch) with the CISCO_WIRELESS_LIGHTWEIGHT_AP_EVENT macro event.  What version of code are you running?
We are running 12.2(55)SE3.  So, this bug is for both the 1142 and 3502?
The fix for this bug should handle both regardless of whether or not they are native lightweight or were converted to lightweight.
We finally had a chance to update the IOS to 12.2(55)SE8.  The 1142N is still causing the CISCO_ROUTER_EVENT to trigger.
Here is some more info:
cs-VangPao-M-C#sh run | b 7/0/1
interface GigabitEthernet7/0/1
macro description CISCO_ROUTER_EVENT
cs-VangPao-M-C#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE8,
RELEASE SOFTWARE (fc2)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 26-Jun-13 09:56 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
Device ID: VangPao107_APa44c.117f.8a77
Entry address(es):
  IP address: 10.20.0.118
Platform: cisco AIR-LAP1142N-A-K9,  Capabilities: Router Trans-Bridge
Interface: GigabitEthernet7/0/1,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 174 sec
Version :
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.2(4)JA1, RELEASE S
OFTWARE (fc2)
Compiled Tue 30-Jul-13 23:25 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 15.400 Watts
Power request id: 9536, Power management id: 2
Power request levels are:15400 14500 0 0 0
Management address(es):
Entry address(es):
Holdtime : 174 sec
Version :
OFTWARE (fc2)
Duplex: full
Any other thoughts here?
The problem is the "Router" capability of the AP.  I found a bug that was unreproducible that hinted controller version may have something to do with this.  I'm not sure what controller version you're using, but perhaps a change in controller code will fix this.  Unfortunately, I couldn't find any more specifics on this as the one customer that encountered it (in controller 7.3.101 code) just used the CISCO_ROUTER_EVENT as a workaround.
556
