supressing output in a TcL script on NX-OS
I am running a TcL script on a Nexus 7k and would like to suppress the output from cli commands.  The TcL book says it can be done by enteringt "log_user 0", which works on a ASR router but not the Nexus switch.
Any suggestions would be appreciated.
Everyone's tags (1)
Tcl on NX-OS is not the same as IOS.  The log_user command does not work.  As a workaround, make the last command something that doesn't display any output.  For example:
cli "show version" ; puts ""
On a nexus 5500 running 5.1(3)N2(1b) -- using the workround of adding a blank command at the end doesn't work either.
I'm trying to find a solution as well.  Doing a large number of show commands, using regex to trim the results to just what I want, and then display only the bits we're interested in, in the format we want.  But preferrably without all the junk scrolling by as the script runs.
I'm also trying to do something similiar to sojouner9 just not as complicated..  I"m just trying to make a known IOS ping script, just as pretty on nx-os.  It runs fine but I need to supress the pings results out from the script.  Here is the script and the results.... Any help of course is appreciate.
puts ""
cli "show clock"
puts " -- Start pinging ..."
puts ""
foreach i {
10.205.10.1
10.228.10.1
if {[regexp "64" [exec "ping $i cou 3" ]]} {puts "$i OK"} else {puts "$i ***unreachable***"}
puts ""
puts ""
cli "show clock"
puts "-- Pings stopped."
### Results when ran ####
switch#
tclsh bootflash:psr.tcl
15:00:42.566 EST Fri Jan 31 2014
PING 10.205.10.1 (10.205.10.1): 56 data bytes
64 bytes from 10.205.10.1: icmp_seq=0 ttl=248 time=33.955 ms
64 bytes from 10.205.10.1: icmp_seq=1 ttl=248 time=33.884 ms
64 bytes from 10.205.10.1: icmp_seq=2 ttl=248 time=33.828 ms
--- 10.205.10.1 ping statistics ---
3 packets transmitted, 3 packets received, 0.00% packet loss
round-trip min/avg/max = 33.828/33.889/33.955 ms
10.205.10.1 OK
PING 10.228.10.1 (10.228.10.1): 56 data bytes
64 bytes from 10.228.10.1: icmp_seq=0 ttl=254 time=0.756 ms
64 bytes from 10.228.10.1: icmp_seq=1 ttl=254 time=0.602 ms
64 bytes from 10.228.10.1: icmp_seq=2 ttl=254 time=0.577 ms
--- 10.228.10.1 ping statistics ---
round-trip min/avg/max = 0.577/0.645/0.756 ms
10.228.10.1 OK
15:00:42.918 EST Fri Jan 31 2014
-- Pings stopped.
It looks like a limitation (at least on N7K) of the exec and cli commands.  Other "set" results can be suppressed using the puts trick.  I couldn't find an existing enhancement request on this, so I suggest you contact your account team to raise one.
It's been a long time on this
It's been a long time on this one. I wish it worked... seems like a no brainer to me. TCL is an old language; the ability to store output in a variable (thus not displaying it) for further processing through its string manipulation facilities is fundamental.
there is a way to do this.
there is a way to do this. there is the 'clis' command which is a silent cli (no output to stdout). it works like this:
set data [clis "sh sys uptime"]
puts "data\n----\n$data"
nxos# tclsh test.tcl
data
System start time: Tue Jul 5 08:11:46 2016
System uptime: 3 days, 5 hours, 40 minutes, 57 seconds
Kernel uptime: 3 days, 5 hours, 42 minutes, 44 seconds
nxos#
1223
