Tcl Script Assistance/Modification
Hello Community,
I've converted an EEM to Tcl using the tool on this site. However, I'm getting the following error:
R3(config)#event manager policy OjectTracking.tcl
EEM Register event failed: Error empty reg spec, policy does not start with EEM registration commands.
EEM configuration: failed to retrieve intermediate registration result for policy OjectTracking.tcl
Can someone please take a little look at the script and let me know what's wrong?
::cisco::eem::event_register_track tag SLA1 1 state down
::cisco::eem::event_register_track tag SLA2 2 state down
::cisco::eem::event_register_track tag SLA3 3 state down
::cisco::eem::trigger {
    ::cisco::eem::correlate event SLA1 or event SLA2 or event SLA3
# This EEM tcl policy was generated by the EEM applet conversion
# utility at http://www.marcuscom.com/convert_applet/
# using the following applet:
# event manager applet object
#  event tag SLA1 track 1 state down
#  event tag SLA2 track 2 state down
#  event tag SLA3 track 3 state down
#  trigger
#   correlate event SLA1 or event SLA2 or event SLA3
#  action 1.0 syslog msg "Track $_event_tag1 is down"
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
action_syslog msg "Track $_event_tag1 is down"
Cheers
Carlton
On what version of IOS are you trying to register this Tcl policy?
Hi Joseph,
The IOS is:
Cisco IOS Software, 7200 Software (C7200-SPSERVICESK9-M), Version 15.0(1)M9, RELEASE SOFTWARE (fc1)
Cheers
I should mention I'm using GNS3
Cheers
Try converting it again and use that version.
Joseph,
I'm not sure what you mean by 'that version'?
Hi Joseph,
Just so you know, I tried loading the script to a 3660, just in case the problem was with the 7206. When I do so I get the following on the 3660:
R3(config)#even ma p OjectTracking.tcl
Compile check and registration failed:policy file does not start with event register cmd
Tcl policy execute failed: policy file does not start with event register cmd
Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy OjectTracking.tcl: Unknown error 0
Sorry Joseph, I understand what you meant.
I recreated the script and applied it but still get the following error:
R3(config)#even ma p objectv2.tcl
Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy objectv2.tcl: Unknown error 0
R3(config)#
Hi Joseph,
Back on the 7206 and I get the following error:
R3(config)#even manager pol objectv2.tcl
EEM configuration: failed to retrieve intermediate registration result for policy objectv2.tcl
Reconvert it again.  That version should work.
Re: Tcl Script Assistance/Modification
Hi Joseph,
I have reconverted a number of times, however I'm still getting the same error message.
If you get some time, do you think you could take a quick look at it?
Cheers
I can register this policy just fine.  Make sure you're trying THIS version.
Joseph,
Sorry, but I don't know what you mean when you say THIS version.
Do you mean the version from the site that i use to convert the EEM? If so, I can only use the version that is provided on the site.
Again sorry but I don't understand
Cheers
I mean the version you attached to this thread or the version you'd get by converting your applet now will register.  I tried it so I know it works.
Joseph,
I re-converted but still getting the following error:
R3(config)#even mana pol objectv4.tcl
EEM configuration: failed to retrieve intermediate registration result for policy objectv4.tcl
It works for me.  Perhaps your device doesn't support the track ED?
Hi Joseph,
Thanks for getting back to me, I do believe the device supports ED:
R3#show event manager version
Embedded Event Manager Version 3.10
Component Versions:
eem: (v310_throttle)4.1.23
eem-gold: (v310_throttle)1.0.7
eem-call-home: (v310_throttle)1.0.6
Event Detectors:
Name                Version   Node        Type
application         01.00     node0/0     RP
syslog              01.00     node0/0     RP
track               01.00     node0/0     RP
resource            01.00     node0/0     RP
routing             02.00     node0/0     RP
cli                 01.00     node0/0     RP
counter             01.00     node0/0     RP
interface           01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
none                01.00     node0/0     RP
oir                 01.00     node0/0     RP
snmp                01.00     node0/0     RP
snmp-notification   01.00     node0/0     RP
timer               01.00     node0/0     RP
ipsla               01.00     node0/0     RP
snmp-object         01.00     node0/0     RP
test                01.00     node0/0     RP
config              01.00     node0/0     RP
env                 01.00     node0/0     RP
gold                01.00     node0/0     RP
nf                  01.00     node0/0     RP
rpc                 01.00     node0/0     RP
R3#
Paste the exact output when you "more" the file as you have copied it to the router.
Hi Joseph,
The output is just a load of numbers, see attached.
You need to upload the file as a plain ASCII text file.  I'm not sure how you're transferring it to the router, but that's clearly wrong.
Joseph,
I've uploaded the file using tftp server.
I've successfully uploaded other .tcl files from this site.
I don't think I'm doing anything different....
I don't know what more to tell you.  This is a hex dump of an ASCII file, not the raw file itself.  You need to get the raw ASCII file loaded on flash.
Hi Joseph,
I'll play around and see what I can do.
Thanks for your help anyway mate.
Joseph,
Just so you know the file is being loaded onto disk0:
Joseph,
Do you think you could convert it for me - just in case I'm converting incorrectly?
Cheers
I just downloaded the attached file you posted,  copied it to my router using TFTP, and registered it.  It worked.  It's  not a question of your file, but how it appears on flash.  Either how  you're saving it locally or how you're transferring it is not preserving  the original structure.
Success!
Joseph,
You were correct. The problem is the way I copy the file to the tftp server.
I simply extracted object4.tcl.zip, you tested in the previous post and I got no errors registering.
Now got to try and test it out.
Cheers mate.
Hi Joseph,
The problem I have now is that a need environment variable for $_event_tag1. But that variable represents, SLA1 or SLA2 or SLA3
*Jul 18 22:28:37.643: %TRACKING-5-STATE: 2 ip sla 2 reachability Up->Down
can't read "_event_tag1": no such variable
while executing
"action_syslog msg "Track $_event_tag1 is down""
invoked from within
"$slave eval $Contents"
(procedure "eval_script" line 7)
invoked from within
"eval_script slave $scriptname"
invoked from within
"if {$security_level == 1} {       #untrusted script
interp create -safe slave
interp share {} stdin slave
interp share {} stdout slave
Multi-event is different in Tcl.  You have to test for each tag:
array set mar_einfo [event_reqinfo_multi]
set tag {}
foreach tag [list "SLA1" "SLA2" "SLA3"] {
    if { [info exists mar_einfo($tag)] } {
        break
action_syslog msg "Track $tag is down"
Wow!
Where would I add that to the Tcl?
Seriously, if its too much trouble just point me in the right direction and I'll try and figure it out - you've helped me a great deal...
Joseph,
I got it to work.
You're a genius! Seriously, I was about to give up.
Thank you so much mate.
481
