01-31-2014 09:51 AM
Hello Community,
I've compiled the attached script with the help of others from this forum.
During the registration I get the following error:
Router(config)#even ma p ISPTest.tcl
Compile check and registration failed:syntax error in expression "$arr_einfo(condition) == Occurred"
("if" test expression)
while compiling
"if {$arr_einfo(condition) == Occurred} {
if [catch {cli_open} result] {
error $result $errorInfo
} else {
array set cli1 $res..."
Tcl policy execute failed: syntax error in expression "$arr_einfo(condition) == Occurred"couldn't compile policy file to bytecode: Unknown error 0
Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy ISPTest.tcl: Unknown error 0
I wonder if someone could take a look at the script and let me know how I might fix it?
Cheers
Solved! Go to Solution.
02-02-2014 03:16 PM
01-31-2014 03:48 PM
02-01-2014 03:44 AM
Joseph,
Thanks ever-so-much for responding.
I will check out your version and let you if it works?
Cheers mate
02-01-2014 01:52 PM
Hi Joseph,
I tried your script. However, I'm getting the following error message when I try to register the script
Router(config)#even man p ISPTest.tcl
Compile check and registration failed:invalid command name "::cisco::eem::event_register_ipsla"
while executing
"::cisco::eem::event_register_ipsla operation_id 102 reaction_type timeout
Tcl policy execute failed: invalid command name "::cisco::eem::event_register_ipsla"
Router(config)#
02-01-2014 02:28 PM
Hello Joseph,
It worked!
I was trying to register on router that didn't support event ip sla.
Star man.
Cheers mate.
02-02-2014 11:59 AM
Joseph,
While carrying out a full test with the script I incurred the following error:
*Feb 2 19:47:58.511: %HA_EM-6-LOG: ISPTest.tcl: Primary Internet Circuit UP
*Feb 2 19:47:58.515: %HA_EM-6-LOG: ISPTest.tcl: can't read "cli1(fd)": no such variable
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: while executing
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "cli_exec $cli1(fd) "enable""
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: invoked from within
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "$slave eval $Contents"
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: (procedure "eval_script" line 7)
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "eval_script slave $scriptname"
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "if {$security_level == 1} { #untrusted script
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: interp create -safe slave
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: interp share {} stdin slave
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: interp share {} stdout slave
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: ..."
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: (file "tmpsys:/lib/tcl/base.tcl" line 50)
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: Tcl policy execute failed:
*Feb 2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: can't read "cli1(fd)": no such variable
I wonder if you could take another look and let me know where it might be going wrong?
Cheers
Carlton
02-02-2014 03:16 PM
02-02-2014 03:54 PM
Hi Joseph,
Going to try it now.
Will let you know.
Thanks in advance
02-02-2014 04:13 PM
Joseph,
Perfect.
Cheers mate.
Carlton
