Tcl Script Check Please Pt1
Hello Community,
I've compiled the attached script with the help of others from this forum.
During the registration I get the following error:
Router(config)#even ma p ISPTest.tcl
Compile check and registration failed:syntax error in expression "$arr_einfo(condition) == Occurred"
    ("if" test expression)
    while compiling
"if {$arr_einfo(condition) == Occurred} {
    if [catch {cli_open} result] {
        error $result $errorInfo
    } else {
        array set cli1 $res..."
Tcl policy execute failed: syntax error in expression "$arr_einfo(condition) == Occurred"couldn't compile policy file to bytecode: Unknown error 0
Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy ISPTest.tcl: Unknown error 0
I wonder if someone could take a look at the script and let me know how I might fix it?
Cheers
1 ACCEPTED SOLUTION
Re: Tcl Script Check Please Pt1
Try this version.
Try this version.
Joseph,
Thanks ever-so-much for responding.
I will check out your version and let you if it works?
Cheers mate
Hi Joseph,
I tried your script. However, I'm getting the following error message when I try to register the script
Router(config)#even man p ISPTest.tcl
Compile check and registration failed:invalid command name "::cisco::eem::event_register_ipsla"
    while executing
"::cisco::eem::event_register_ipsla operation_id 102 reaction_type timeout
Tcl policy execute failed: invalid command name "::cisco::eem::event_register_ipsla"
Router(config)#
Hello Joseph,
It worked!
I was trying to register on router that didn't support event ip sla.
Star man.
Cheers mate.
Joseph,
While carrying out a full test with the script I incurred the following error:
*Feb  2 19:47:58.511: %HA_EM-6-LOG: ISPTest.tcl: Primary Internet Circuit UP
*Feb  2 19:47:58.515: %HA_EM-6-LOG: ISPTest.tcl: can't read "cli1(fd)": no such variable
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl:     while executing
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "cli_exec $cli1(fd) "enable""
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl:     invoked from within
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "$slave eval $Contents"
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl:     (procedure "eval_script" line 7)
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "eval_script slave $scriptname"
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: "if {$security_level == 1} {       #untrusted script
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl:      interp create -safe slave
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl:      interp share {} stdin slave
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl:      interp share {} stdout slave
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: ..."
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl:     (file "tmpsys:/lib/tcl/base.tcl" line 50)
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: Tcl policy execute failed:
*Feb  2 19:47:58.519: %HA_EM-6-LOG: ISPTest.tcl: can't read "cli1(fd)": no such variable
I wonder if you could take another look and let me know where it might be going wrong?
Cheers
Carlton
Try this version.
Hi Joseph,
Going to try it now.
Will let you know.
Thanks in advance
Joseph,
Perfect.
Cheers mate.
Carlton
531
