Tcl Script Check Please
Hello Community,
I have been evaluating the attached script. It appeared to work on my GNS3 lab, but when I apply the script to our production equipment it won't work.
I tested it by changing one of the environment variables to:
event manager environment interface_reset_threshold 2
and
event manager environment interface_health_period 10
However, when the interface reset increment to 2 over 10 seconds nothing no email was sent.
I know email is working because I used the sendmail.tcl script.
Can someone please check out the script and let me know if they're able to get it to work?
I've uploaded the script to the following device:
MX-C3750-FL0-S#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
cisco WS-C3750X-48P (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1703H2F9
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
208 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Cheers
Carlton
1 ACCEPTED SOLUTION
Re: Tcl Script Check Please
Community,
I'm thinking that it won't work on 3750 because the format of the interfaces are
GigabitEthernetx/x/x
But not sure
I see no reason why this shouldn't work with 3750-style interface names.  However, it only looks at those interfaces with IP addresses on them.  If you care about non-IP ports, then you likely want to change the command on line 165 to:
sh ip int brief | exc Interface|down|\[0-9\]*/\[0-9\]*\\.\[0-9\]*
Hi Joseph,
Thanks for responding.
All of the ports on the 3750 are switchports, apart from our management ports.
I made the change as you suggested, however I'm now getting the following error when I try to register the policy:
MX-C3750-FL0-S(config)#event manage p composite_device_health.tcl
EEM Register event failed:extra characters after close-quote
    while compiling
""} result] {
    error $result $errorInfo
set interface $result
#--- Fetch interface counter information
for { set i 0 } { $i < [expr [llength $i..."
Any thoughts
Hi Joseph,
I realised that I was being a numpty and fixed the problem.
However, I do have a problem with the script. I get the following error message when the script is activated:
Interface Te1/1/1 interface resets threshold exceeded.
Creating mail header...
composite_device_health_interface.tcl e-mail notification sent!
can't read "i": no such variable
(reading value of variable to increment)
invoked from within
"incr i 6 "
     invoked from within
"$slave eval $Contents"
     (procedure "eval_script" line 7)
     invoked from within
"eval_script slave $scriptname"
     invoked from within
"if {$security_level == 1} {       #untrusted script
      interp create -safe slave
      interp share {} stdin slave
      interp share {} stdout slave
     (file "tmpsys:/lib/tcl/base.tcl" line 50)
Jul 24 16:36:44.630: %HA_EM-6-LOG: composite_device_health.tcl: Tcl policy execute failed:
Jul 24 16:36:44.630: %HA_EM-6-LOG: composite_device_health.tcl: can't read "i": no such variable
I think the problem is with the following line:
set body [format "%s\nSubject: %s\n" "$body" "Interface [ lindex $interface $i ] input errors threshold exceeded!
However, I don't know what impact it will have on the script if I remove $i
Any thoughts?
Cheers
I don't see the problem.  The line you show is not it.  The script you attach does not appear to have a problem incrementing the value of i.
OK, Joseph, that's fine.
However, can you tell me why I get the following error message with the script on some devices but not on others?
Jul 25 22:53:38.974: %HA_EM-7-FMS_POLICY_MAX_ENTRIES: fh_schedule_policy: Class default: Maximum number of 64 script publish entries exceeded; some events have been discarded
Cheers
Carlton
Brilliant.
Cheers mate.
569
