Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
TCL Script hangs with gets and ctrl-c
Hi guys,
I have a TCL script that I am writing which displays a menu and allows the user to choose different options to view the status of customer circuits, etc.  The script is pure TCL, since I need it to work on both IOS and IOS-XR (which does not support EMM).
When the script is at the prompt, waiting for user input and Ctrl-C is issued, at least half the time, the router will hang completely, and after a minute or two, go into software reset.  The router I am testing the script on is a 2821 running 12.4.7a, and the relevant code-snippets are included below.
Has anyone noticed this behavior before?
rray set base_menu {
               1 "List Customers and Status"
               2 "Display recent circuit bounces"
               3 "Display Port Information for a Specific Customer"
               9 "Exit"
proc header {} {
    puts "xxxx"
    puts [clock format [clock seconds] -format "%A, %B %d,%Y %H:%M:%S"]
proc print_menu {_menu} {
    upvar $_menu my_menu
    set prompt "-> "
    header
    foreach {idx val} [array get my_menu] {
        puts "$idx. $val"
    puts -nonewline $prompt
    flush stdout
proc handle_input {input} {
    switch $input {
        1 {
            get_cust_info
            return
        2 {
            puts "Bounces"
            return
        3 {
            puts "Port info"
            return
        9 {
            return -1
        default {
            print_menu base_menu
            return
while 1 {
    set rval [handle_input [gets stdin]]
    if {$rval == -1} {
        break
Everyone's tags (1)
This sounds similar to an old bug that is fixed in your version of code (though your code is very old).  Post the show ver output as well as the output of "show stack" and "show region" from this router after reproducing the crash.
Joe,
Thanks for the reply.  Here is the output:
ch-emmtest-1#show ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(7a), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 25-Apr-06 04:00 by ssearch
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
ttnet-ch-emmtest-1 uptime is 17 hours, 53 minutes
System returned to ROM by error - a Software forced crash, PC 0x4008BAF0 at 21:02:04 UTC Mon Jun 25 2012
System image file is "flash:c2800nm-advsecurityk9-mz.124-7a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1012A5E6
11 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
ch-emmtest-1#show stack
Minimum process stacks:
Free/Size   Name
4868/6000   USB Startup
5344/6000   Inspect Init Msg
5336/6000   SPAN Subsystem
5152/6000   DIB error message
11016/12000  Router Init
7096/12000  Init
5152/6000   RADIUS INITCONFIG
3872/6000   RAC I/F Conf.
2096/3000   Rom Random Update Process
34852/36000  TCP Command
9640/12000  Virtual Exec
Interrupt level stacks:
Level    Called Unused/Size  Name
  1      584526   7776/9000  Network interfaces
  2      532410   8560/9000  DMA/Timer Interrupt
  3           1   8320/9000  PA Management Int Handler
  4         248   8544/9000  Console Uart
  5           0   9000/9000  External Interrupt
  7    16098093   8568/9000  NMI Interrupt Handler
System was restarted by error - a Software forced crash, PC 0x4008BAF0 at 21:02:04 UTC Mon Jun 25 2012
Image text-base: 0x400A2B6C, data-base: 0x41C40000
Stack trace from system failure:
FP: 0x43794440, RA: 0x4008BAF0
FP: 0x43794440, RA: 0x400897E8
FP: 0x43794468, RA: 0x4009CD90
FP: 0x43794488, RA: 0x4009D228
FP: 0x437944B0, RA: 0x4008DE90
FP: 0x43794548, RA: 0x400CD320
FP: 0x43794578, RA: 0x400CD3FC
FP: 0x43794590, RA: 0x400CDC60
******* Information of Last System Crash **********
Using flash:crashinfo_20120625-210204.
Writing crashinfo to flash:crashinfo_20120625-210204ot part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43D936C4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43E89624, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43E8F974, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43E8FC04, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43E94C50, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43EB1A74, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43EB1E04, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43EB7774, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43EB7B04, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43EC3BF4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43EC3E84, not part of buffer pool -Traceback=
*Jun 25 21:02:01.411: %SYS-2-FREEBAD: Attempted to free memory at 43ED2A3C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43EDAD94, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43EEADC8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43EED50C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43EF1EF0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43EFEC08, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43F13A54, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43F1461C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43F1D2EC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 43FF5ABC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 440030B8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 44006A6C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 44016BB0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 440192F4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 4401BA38, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 44026858, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 44045834, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 44058BC0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 44068BF4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 4407AD64, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 4408AF8C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 4409B01C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 440A3050, not part of buffer pool -Traceback=
*Jun 25 21:02:01.415: %SYS-2-FREEBAD: Attempted to free memory at 440A3F84, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440A4B70, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440A4EEC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440A87A0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440B87D4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440BD628, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440DF098, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440EF0CC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 440FF100, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 44117860, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 44127894, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 441378C8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 441478FC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 44157F54, not part of buffer pool -Traceback=
*Jun 25 21:02:01.419: %SYS-2-FREEBAD: Attempted to free memory at 44183864, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 44194154, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4419465C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4419534C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 441A8AA4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 441B9184, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 441DA9B8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 441E2FB8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4420EDD0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4420FD38, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 44218334, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 442333D8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4440E6E8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4436BC40, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 44410E2C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4436E384, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4442C978, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 44434BD4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 44439D14, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4443C6AC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4437B5D0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4443F984, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4437A77C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 4423D9F0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.423: %SYS-2-FREEBAD: Attempted to free memory at 443A6DC0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 443A7F1C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 44240D90, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 4424110C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 44249140, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 443A89DC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 4424BE34, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 4445D2F0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 4425300C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 444622C0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 443DA4A4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 443E03A4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 44253D64, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 44465F18, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 44409F1C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 4440A0A4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 4440A3B0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.427: %SYS-2-FREEBAD: Attempted to free memory at 4426D610, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 44487084, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 44283E74, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442842BC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444C2068, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 4428BCA8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444C93C4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 4428E3EC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444CBCB4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442900E8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444CE3F8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442902B0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444D0088, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 4429B318, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444DE928, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444E001C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442A5584, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444E1F40, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442BB47C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442BF09C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444E91AC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444ECCA4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442D3DFC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 444EE060, not part of buffer pool -Traceback=
*Jun 25 21:02:01.431: %SYS-2-FREEBAD: Attempted to free memory at 442D49E8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 444F07A4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442D5DA4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 444F2EE8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442D7160, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 444F3148, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442D7D4C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 444F33A8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442E0B10, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442DD354, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 444FDE0C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442F8030, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 44500980, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442FCE84, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 442FE2D8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 44302830, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 4450E398, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 44312864, not part of buffer pool -Traceback=
*Jun 25 21:02:01.435: %SYS-2-FREEBAD: Attempted to free memory at 4451E3CC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 44322898, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 4432A8CC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 4433A900, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 4434A934, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 445342F4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 44534784, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 44596DA4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 445AB4E0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 445B3BDC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 445DE0D0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 446032A4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.439: %SYS-2-FREEBAD: Attempted to free memory at 4459AB60, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 446E1584, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44701AE4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 447026D0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44704E14, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44707558, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44709C9C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 4470A888, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 4470BC44, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 4471BC78, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 4471D034, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 4471F778, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44721EBC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44722238, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44722848, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 44722E58, not part of buffer pool -Traceback=
*Jun 25 21:02:01.443: %SYS-2-FREEBAD: Attempted to free memory at 446B077C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 446C1330, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 44746BF8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 44766C50, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 44776C84, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 44786CB8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 44787F14, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 44788AA8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 447890B8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.447: %SYS-2-FREEBAD: Attempted to free memory at 44791C80, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 4475E108, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 441C3C08, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447238B8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 44021060, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447AB074, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 441D4644, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 441C8A5C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447C79A0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B5A40, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 437707B8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 4376E774, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B91AC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 4377526C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 446F4F34, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B8B9C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447C9CD8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 4377FE38, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 43B9CFF4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 43B9D604, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 43B9E1F0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B6E64, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 441CD8B0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 441CDEC0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 43776CA0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B8008, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 4376B780, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B2AEC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B1F58, not part of buffer pool -Traceback=
*Jun 25 21:02:01.451: %SYS-2-FREEBAD: Attempted to free memory at 447B13C4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 447B0830, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 441CEAAC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 43777E44, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 447B7474, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 441CF640, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 437795F8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 441D01D4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 43753DF0, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 441D0D68, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 447A1CB4, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 4375504C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 447A43F8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.455: %SYS-2-FREEBAD: Attempted to free memory at 437562A8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 447E0540, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 437A3E70, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 447E0604, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 437A3F34, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 447E06C8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 437A3FF8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 447E078C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 437A40BC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 447E0850, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 437A4180, not part of buffer pool -Traceback=
*Jun 25 21:02:01.459: %SYS-2-FREEBAD: Attempted to free memory at 447E0914, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 437A4244, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 447E09D8, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 437A4308, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 447E0A9C, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 437A43CC, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 447E0B60, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 437A4490, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 447E0C24, not part of buffer pool -Traceback=
*Jun 25 21:02:01.463: %SYS-2-FREEBAD: Attempted to free memory at 437A4554, not part of buffer pool -Traceback=
*Jun 25 20:59:58.415: %SYS-3-CPUHOG: Task is running for (6012)msecs, more than (2000)msecs (5/3),process = Tcl Serv - tty322.
-Traceback= 0x4009A6E4 0x4009A134 0x41C1025C 0x4161CE14 0x41663D6C 0x4166292C 0x416623C4 0x4166742C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x4164271C
*Jun 25 21:00:00.419: %SYS-3-CPUHOG: Task is running for (8012)msecs, more than (2000)msecs (6/3),process = Tcl Serv - tty322.
-Traceback= 0x4009A0B4 0x4009A13C 0x41C1025C 0x4161CE14 0x41663D6C 0x4166292C 0x416623C4 0x4166742C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x4164271C
*Jun 25 21:02:02.195: %SYS-2-FREEBAD: Attempted to free memory at 447E0CE8, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 437A4618, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 447E0DAC, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 437A46DC, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 447E0E70, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 437A47A0, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 447E0F34, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 437A4864, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 447E0FF8, not part of buffer pool -Traceback=
*Jun 25 21:02:02.199: %SYS-2-FREEBAD: Attempted to free memory at 437A4928, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 447E10BC, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 437A49EC, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 447E1180, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 437A4AB0, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 447E1244, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 437A4B74, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 447E1308, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 437A4C38, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 447E13CC, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 437A4CFC, not part of buffer pool -Traceback=
*Jun 25 21:02:02.203: %SYS-2-FREEBAD: Attempted to free memory at 447E1490, not part of buffer pool -Traceback=k is running for (16012)msecs, more than (2000)msecs (6/3),process = Tcl Serv - tty322.
-Traceback= 0x4009A6F0 0x4009A134 0x41C1025C 0x4161CE14 0x41663D6C 0x4166292C 0x416623C4 0x4166742C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x4164271C
*Jun 25 21:02:02.531: %SYS-2-FREEBAD: Attempted to free memory at 437A4DC0, not part of buffer pool -Traceback=
*Jun 25 21:00:10.427: %SYS-3-CPUHOG: Task is running for (18016)msecs, more than (2000)msecs (7/3),process = Tcl Serv - tty322.
-Traceback= 0x4161CE40 0x41663D6C 0x4166292C 0x416623C4 0x4166742C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88
*Jun 25 21:00:12.423: %SYS-3-CPUHOG: Task is running for (20012)msecs, more than (2000)msecs (7/3),process = Tcl Serv - tty322.
-Traceback= 0x4009A6E4 0x4009A134 0x41C1025C 0x4166A1BC 0x41663DF0 0x4166292C 0x416623C4 0x4166742C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x4164271C
*Jun 25 21:02:03.279: %SYS-2-FREEBAD: Attempted to free memory at 447E1554, not part of buffer pool -Traceback=
*Jun 25 21:00:14.427: %SYS-3-CPUHOG: Task is running for (22016)msecs, more than (2000)msecs (7/3),process = Tcl Serv - tty322.
-Traceback= 0x416628E8 0x416623C4 0x4166742C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x41658800 0x41676D58
*Jun 25 21:00:16.423: %SYS-3-CPUHOG: Task is running for (24012)msecs, more than (2000)msecs (7/3),process = Tcl Serv - tty322.
-Traceback= 0x4009A0C4 0x4009A13C 0x41C1025C 0x4161CE14 0x41663D6C 0x4166292C 0x416623C4 0x4166742C 0x41651F50 0x41657F24 0x41634C88 0x4164271C 0x41651F50 0x41657F24 0x41634C88 0x4164271C
*Jun 25 21:02:04.031: %SYS-2-FREEBAD: Attempted to free memory at 3F9894E0, not part of buffer pool -Traceback=
*Jun 25 21:02:04.031: %SYS-2-FREEBAD: Attempted to free memory at 447DD7F4, not part of buffer pool -Traceback=
*Jun 25 21:02:04.031: %SYS-2-FREEBAD: Attempted to free memory at 3F98B8A0, not part of buffer pool -Traceback=
*Jun 25 21:02:04.031: %SYS-2-FREEBAD: Attempted to free memory at 437A2290, not part of buffer pool -Traceback=
21:02:04 UTC Mon Jun 25 2012: Breakpoint exception, CPU signal 23, PC = 0x4008BAF0
   Possible software fault. Upon reccurence,  please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 0x4008BAF0
$0 : 00000000, AT : 434E0000, v0 : 446B0718, v1 : 0007DE4C
a0 : 446B06E8, a1 : 446B06E8, a2 : 00000005, a3 : 436C0000
t0 : 447CBB18, t1 : 43BA3DE0, t2 : AAE60000, t3 : 00000000
t4 : 000002C4, t5 : 00000425, t6 : 00000000, t7 : 00000000
s0 : 434D0000, s1 : 00000003, s2 : 43120000, s3 : 42FA0000
s4 : 00000000, s5 : 41C70000, s6 : FFFF0000, s7 : 03BF0000
t8 : 444563D0, t9 : 0001FBD0, k0 : 447CBB18, k1 : 4009D140
gp : 43338E60, sp : 43794440, s8 : 03FF0000, ra : 400897E8
EPC  : 4008BAF0, ErrorEPC : BFC00E8C, SREG     : 3400FF03
MDLO : 00000000, MDHI     : 00000000, BadVaddr : 7FFD366E
Cause 00000024 (Code 0x9): Breakpoint exception
Process watchdog registers:
$0 : 00000000, AT : 43330000, v0 : 00000001, v1 : 43357080
a0 : 00000000, a1 : 43357080, a2 : 00000000, a3 : 41651F50
t0 : 0000C100, t1 : 3400C101, t2 : 4008FC30, t3 : FFFF00FF
t4 : 4008FC10, t5 : 000089B9, t6 : 00000008, t7 : 4379487C
s0 : 41C70000, s1 : 43357028, s2 : 41654030, s3 : 42FA0000
s4 : 00000001, s5 : 41C70000, s6 : FFFF0000, s7 : 03BF0000
t8 : 447AF170, t9 : 00000000, k0 : 447CBB18, k1 : 400CD320
gp : 43338E60, sp : 43794548, s8 : 03FF0000, ra : 400CD2C8
EPC : 400CD320, SP : 43794548, forkx : 447CBB18
=== Start of Crashinfo Collection (21:02:04 UTC Mon Jun 25 2012) ===
For image:
========= Show Alignment =============================
No alignment data has been recorded.
No spurious memory references have been recorded.
========= Malloc and Free Traces=====================
MallocFree Trace: ixmallocfree=0x37  ptr=0x434DA848
========= Chunk Malloc and Chunk Free Traces=====================
========== Stack Trace========
========= Context ======================
Signal = 23, Code = 0x24, Uptime 00:17:46
EPC : 4008BAF0, SREG : 3400FF03, Cause : 00000024
Error EPC : BFC00E8C, BadVaddr : 7FFD366E
========= Stack Dump ==========================
Stack Frame Pointer in Context is 0x43794548 , intstacks corrupted
: INVALID STACK ADDRESS
========= Process Level Info ==================
Regs s0-s8,ra at last suspend; a0,a1,sp from proc creation, PC unused:
     a0: 41622C80  a1: 00000000  s0: 434D0000  s1: 00000BB8  s2: 43120000
     s3: 42FA0000  s4: 00000000  s5: 41C70000  s6: FFFF0000  s7: 03BF0000
     s8: 03FF0000  sp: 43795DA8  PC: 00000000  ra: 416E30E8
========= Interrupt Level Stack Dump ==========
WARNING: Interrupt stack dumps are consistent ONLY for interrupts which
are blocked during exception handling.  Also register output is valid
ONLY for interrupts which store an r4k_context block on the stack.
---- Level 1 Interrupt stack (base 0x0, size 0x2328) is invalid ----
---- Level 2 Interrupt stack (base 0x0, size 0x2328) is invalid ----
---- Level 3 Interrupt stack (base 0x0, size 0x2328) is invalid ----
---- Level 4 Interrupt stack (base 0x0, size 0x2328) is invalid ----
---- Level 5 Interrupt stack (base 0x0, size 0x2328) is invalid ----
---- Level 6 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 7 Interrupt stack (base 0x0, size 0x2328) is invalid ----
========= Register Memory Dump ================
Registers at process watchdog timeout:
Reg00($0):        0 [Not RAM Addr]
Reg01(AT): 43330000 [Not RAM Addr]
Reg02(v0):        1 [Not RAM Addr]
Reg03(v1): 43357080 [Not RAM Addr]
Reg04(a0):        0 [Not RAM Addr]
Reg05(a1): 43357080 [Not RAM Addr]
Reg06(a2):        0 [Not RAM Addr]
Reg07(a3): 41651F50 [Not RAM Addr]
Reg08(t0):     C100 [Not RAM Addr]
Reg09(t1): 3400C101 [Not RAM Addr]
Reg10(t2): 4008FC30 [Not RAM Addr]
Reg11(t3): FFFF00FF [Not RAM Addr]
Reg12(t4): 4008FC10 [Not RAM Addr]
Reg13(t5):     89B9 [Not RAM Addr]
Reg14(t6):        8 [Not RAM Addr]
Reg15(t7): 4379487C [Not RAM Addr]
Reg16(s0): 41C70000 [Not RAM Addr]
Reg17(s1): 43357028 [Not RAM Addr]
Reg18(s2): 41654030 [Not RAM Addr]
Reg19(s3): 42FA0000 [Not RAM Addr]
Reg20(s4):        1 [Not RAM Addr]
Reg21(s5): 41C70000 [Not RAM Addr]
Reg22(s6): FFFF0000 [Not RAM Addr]
Reg23(s7):  3BF0000 [Not RAM Addr]
Reg24(t8): 447AF170 [Not RAM Addr]
Reg25(t9):        0 [Not RAM Addr]
Reg26(k0): 447CBB18 [Not RAM Addr]
Reg27(k1): 400CD320 [Not RAM Addr]
Reg28(gp): 43338E60 [Not RAM Addr]
Reg29(sp): 43794548 [Not RAM Addr]
Reg30(s8):  3FF0000 [Not RAM Addr]
Reg31(ra): 400CD2C8 [Not RAM Addr]
buffer check=0 sched_hc=0x0
========= End of Crashinfo Collection ================
ch-emmtest-1#         show region
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x0F400000  0x0FFFFFFF    12582912  Iomem  R/W    iomem:(uncached_iomem_region)
0x3F400000  0x3FFFFFFF    12582912  Iomem  R/W    iomem
0x40000000  0x4F3FFFFF   255852544  Local  R/W    main
0x4000F000  0x41C3FFFF    29560832  IText  R/O    main:text
0x41C40000  0x43332A5F    24062560  IData  R/W    main:data
0x43332A60  0x43753DBF     4330336  IBss   R/W    main:bss
0x43753DC0  0x4F3FFFFF   197837376  Local  R/W    main:heap
0x80000000  0x8F3FFFFF   255852544  Local  R/W    main:(main_k0)
0xA0000000  0xAF3FFFFF   255852544  Local  R/W    main:(main_k1)
Free Region Manager:
This is CSCsd35622, which is fixed in 12.4(8).  I recommend you get to the latest 12.4 mainline image, though.
Joe,
That fixed the problem.  Thanks for the help!
-Nick
1202
