Tcl Script on Device Not Supporting EEM Features
Hello Community,
This may be a dumb question, however is it possible to apply a Tcl script to a device that doesn't support certain EEM commands.
For example, I'm about to convert the following EEM commands to Tcl using the EEM converter.
event manager applet object
event tag SLA1 track 1 state down
event tag SLA2 track 2 state down
event tag SLA3 track 3 state down
trigger
  correlate event SLA1 or event SLA2 or event SLA3
action 1.0 syslog msg "Track $_event_tag1 is down"
However, I'm going to register the converted Tcl on a device that doesn't support, things like trigger, correlate or event tag.
Will the script still work?
Cheers
Carlton
1 REPLY
No.  Even with Tcl you need to adhere to minimum EEM versions.  Multi-event support requires EEM 2.4 or higher.
247
