tclsh and TACACS+
nasvos
Is there a trick to getting tcl scripts (or even just the tclsh command) to work in a TACACS+ environment?  I was trying to run a tcl script that I copied to the device, and got "command authoriziation failed".  Running tclsh by itself and trying to exec a command yielded the same results, even after setting the event manager user to the currently logged in user.
I tried this on two different deviecs, a 6500 running 12.2.33SXI9 and a 4900M running 12.2.54SG1.  The failed commands show up in tacacs with no username and as async...
Example:
ttnet-ch-rocore-1>en
Password:
ttnet-ch-rocore-1#tclsh
ttnet-ch-rocore-1(tcl)#exec "show ver"
Command authorization failed.
ch-rocore-1(tcl)#exit
ch-rocore-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ch-rocore-1(config)#event manager session cli user xXxXx
ch-rocore-1(config)#exit
ch-rocore-1#tclsh
AAA config:
aa new-model
aaa authentication login default group tacacs+ local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 noauth none
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 1 noauth none
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa authorization commands 15 noauth none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
Thanks!
-Nick
Joe Clarke
This is CSCsu65401, which is not fixed in your versions of code.  Might I suggest you use EEM Tcl?  With EEM, you have tighter control over how AAA is used (using the event manager session cli user command).  I'm not sure what your end goal is, but I'm sure you could accomplish it using either EEM applets or Tcl scripts.
