use EEM to match a portion of output
Hi. I need to use EEM to run a command (actually "show isdn status" command) and inspect the output for the term "MULTIPLE_FRAME_ESTABLISHED" which indicates the L2 status of the E1 line. is there any way to do this with EEM?
and this is sample of the output for this command:
maui-soho-02#show isdn status
Global ISDN Switchtype = basic-ni
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 73, Ces = 2, SAPI = 0, State = TEI_ASSIGNED
TEI = 104, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Spid Status:
TEI 104, ces = 1, state = 6(not initialized)
  • EEM Scripting
Everyone's tags (1)
1 REPLY
Sure.  Here is some applet
Sure.  Here is some applet code you can use.  This assumes you have preceded the lines with "action X"
cli command "show isdn status"
regexp "MULTIPLE_FRAME_ESTABLISHED" $_cli_result
if $_regexp_result eq 1
 syslog msg "Found Multi frame established"
else
 syslog msg "Did not find multi frame established"
end
189
