Using EEM to telnet to switches and execute commands
Can EEM telnet to other switches.
It doesn't seem to work and when you run debug it drops out at the password for telnet.
I have tried using the "pattern" option to put the telnet password in.  but can't get it to work
All I won't to be able to do is automatically run a few commands on other switches from the core.
Any ideas
Everyone's tags (1)
I can assure you EEM on IOS
I can assure you EEM on IOS can initiate telnet session without a hitch, but on IOX, still struggling to find out the workaroud.
proc remote_cmd_telnet { remote_host username password prompt_expect clist } {
    # this function will carry out each command contained in the clist on remote host.
    if { [catch {cli_open} result] } {
             PUTS $result
             return 1
        } else {
             array set cliarr $result
    #Login to remote router
    if { [catch {cli_write $cliarr(fd) "telnet  $remote_host" } result] } {
         PUTS $result
         return 1
    PUTS $result
#   if { [catch {cli_read_pattern $cliarr(fd) "Username:"} result] } {
#        PUTS error "Failed to read response: '$result'"
#       return 1
#   PUTS $result
    if { [catch {cli_write $cliarr(fd) $username } result] } {
         PUTS $result
         return 1
    PUTS $result
    if { [catch {cli_read_pattern $cliarr(fd) "Password:"} result] } {
        return 1
    PUTS $result
    if { [catch {cli_write $cliarr(fd) $password } result] } {
         PUTS $result
         return 1
    PUTS $result
    if { [catch {cli_read_pattern $cliarr(fd) "#"} result] } {
 Hi  xinchengYes EEM does
Hi  xincheng
Yes EEM does initiate telnet, I can see that from the debug but doesn't seem to accept the password using pattern.  What you have written looks great but way over my head.  I take it it I could just paste it to the switch and that would create the process remote_cms_telnet.
there is no username required, there is just the vty/telnet password.
All I want to do is run a progam that will telnet to various switches and run a few commands on a selection of ports It was 6 commands using EEM but it doesn't work.
Paul
Hi Paul,Please tell me which
Hi Paul,
Please tell me which IOS /IOX version you are running ?
Version 12.2(17r)SX3, RELEASE
Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Paul,I believe that IOS is
Paul,
I believe that IOS is not capable of doing that, like Ivan posted long time ago.
http://blog.ipspace.net/2007/10/you-cannot-start-telnet-session-from.html
If possible, please upgrade to 15.X, which fixed some bugs about eem.
278
