Community Member
WAN Load Alarm Script Modification
Hello Joesph,
You may recall sometime ago I asked if it were possible to modify the attached script to allow for more than one interface. At the time you mentioned that it wasn't possible.
I was just wondering if you had created a script (or modified the existing script) that would send an alert when the utilization on more than one interface crossed a certain threshold?
Cheers
Carlton
1 REPLY
Sorry, no.  This was not something I've been looking into.
753
