Saving C150 configuration without hashed passwords does not work
Hi there,
I have a C150 running 6.5.2-101
I have tried unsuccessfully to save the configuration without hashed passwords - every time I do (gui or cli via email) the xml file contains the encrypted password not clear text.
Has anyone encountered this before - if so, how did you overcome it?
Cheers
Greg Krzeszkowski
1 ACCEPTED SOLUTION
Re: Saving C150 configuration without hashed passwords does not
The passwords in a saveconfig are always encrypted (see note in basic manual).
When saving, showing, or mailing your configuration file if you choose to include
passwords (answer yes to “Do you want to include passwords?”) the passwords are encrypted.
However, the private keys and certificates are included in unencrypted PEM format.
Peter.
Peter.
thanks Peter!
394
