ASK THE EXPERT - CISCO SMALL BUSINESSS
Welcome to the Cisco Networking Professionals Ask the Expert conversation. This is an opportunity to learn more about Cisco Small Business products With Nelson Seto.  Nelson is a Tech Support Engineer for the small business product line of PBX, ATA and IP Phones.  His experience includes SPA9000/400, ATA’s such as PAP2T/SPA2102/3102/8000 and the phones which are the SPA9xx series and SPA5xx series.  He has been in this position at Cisco for almost 5 years assisting our field engineers, sales engineers and service providers.
Remember to use the rating system to let Nelson know if you have received an adequate response.
Nelson might not be able to answer each question due to the volume expected during this event. Our moderators will post many of the unanswered questions in other discussion forums shortly after the event. This event lasts through March 12, 2010. Visit this forum often to view responses to your questions and the questions of other community members.
Community Member
Re: ASK THE EXPERT - CISCO SMALL BUSINESSS
Hello Expert!
I have a scenario I've ran into a few times and I'm having issues finding detailed definitions on codecs and transcoding to answer my question.
Incoming SIP call leg is G729 (CUBE) and outgoing call leg to CUCM is G711.  Do you gain some quality back transcoding to G711 or is it once you go G729 might as well keep it that way?
Thanks.
Community Member
Generally the codec should just remain as is, but there are times when the codec must
be synchronous (in and out) and that's when it would need to change.  Our line of products can be run asynchronous.
Community Member
Hi Expert!
I have Cisco 7940s that reset when you ever you select Network Configurations!  Please, please help!
Firmware Version
Application Load ID
POS3-08-9-00
Boot Load ID
PC030301
DSP Load IP
4.0(2.0)[A0]
Thank you so much!
Drew
Community Member
I'm sorry but that product is handled by a different division within Cisco.  Please call 800 553 2447 or email tac@cisco.com for assistance with this particular phone.  Thank you.
Community Member
Hi there,
can ATAs be configured with certificates so I can establish secure connection with my CUCM (in HQ, behind the firewall) even if ATA is on public network? Which signaling protocols are supported by those ATA's?
P.S. If you are not familiar with CUCM can you let us know if it is working with your IPPBX?
Tenaro
Community Member
It sounds like you are referring to srtp.
You'll want to check the info in the admin guide which explains how to set this up.
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
It will tell you how to configure the unit for srtp which requires you to download and use the program gen_mc in order to generate a mini-cert.
Page 70-73 in the admin guide has this info.
Community Member
Can you have multiple lines on a 7937 phone? I can't figure out a way to make them both show.
Thanks.
Community Member
I'm sorry but the 79xx series is handled by a different division within Cisco.  Please call 800 553 2447 or email tac@cisco.com for assistance with this particular phone.  Thank you.
144
