ASK THE EXPERT- CONFIGURING CISCO IPSEC VPNs
Welcome to the Cisco Networking Professionals Connection Ask the Expert conversation. This is an opportunity to discuss configuring Cisco IPSec VPNs with Cisco expert Mike Wenstrom. Mike is a training manager in the VPN and Security Services business unit at Cisco. Feel free to post any questions relating to Configuring Cisco IPSec VPNs.
Mike may not be able to answer each question due to the volume expected during this event. Our moderators will post many of the unanswered questions in other discussion forums shortly after the event. When posting a question, please be sure it is as specific as possible. Mike will be unable to address questions that require significant time commitments, such as requests for entire network designs or configurations, or vague questions that require follow-up with the poster.
This event lasts through December 21. Visit this forum often to view responses to your questions and the questions of other community members.
Re: ASK THE EXPERT- CONFIGURING CISCO IPSEC VPNs
I have a problem with a three sight VPN configuration. I use three routers (one Cisco 3640 and two Cisco 1720). I can´t connect to the Ms Exchange server behind the Cisco 3604 from the two Cisco 1720 sights. If i remove the static IP assignment applyed for the Ms Exchange server in the Cisco 3640 it works. How should i configure the routers... with the static included in the config?
Kalle,
I assume that you have the 3640 at a central site, and the 1720's remote connecting over a WAN to the central site, and that you are using IPSec to secure traffic from the networks behind the 1720's to the MS Exchange server behind the 3640, I would recommend the following:
Routing
Set up static routes: ip route mask <3640_address>
VPN
configure isakmp policy in routers that matches, config isakmp key or ca support
set up crypto ipsec transform sets in routers
configure access lists to select traffic:
access-l source=net_behind_1720 dest=MS_exchange
configure crypto map: set peer=router's tunnel endpoint
apply crypto map to router dirty interface
test and check with show crypto commands
Hope this answers your question.
Mike.
I need to install and configure an enterprise firewall solution for my network. This solution should use IPSec with Certificate based authentication and needs to create on demand VPN's to about 20 servers located around the country. The 20 servers will have a small firewall configured to route packets only to the PIX firewall and will not have any other internet access. What PIX firewall product best fits this situation.
I would recommend a PIX 525 for your Enterprise core Firewall. It can handle about 256Mbps (30Mbps 3DES) throughput, 2000 IPSec tunnels, and 6000 connections per second. The PIX-525 can also be upgraded with a VPN accelerator card which gives 100Mbps 3DES performance
I would recommend the PIX 506 for the remote sites.
Is supports about 10Mpbs (4Mbps 3DES) throughput.
When will a VPN concentrator 3000 client be available for Windows 2000 ?
Cisco VPN 3000 Client Release 3.0 runs on Windows 2000. It is in beta test now. Your Account Manager / Systems Engineer can get you involved in the beta. The Rel 3.0 client will be released on March 5th, 2001.
Will Cisco VPN Client Release 3.0 also run
on Windows ME? The Client 2.5.2 will not
work proberly on Windows ME!
I do not see VPN client rel 3.0 support on Windows ME, but will forward question to product manager for direct answer. MW
Correction, I have heard that a customer is using the VPN 3K client 2.5.2 on Windows ME (which is essentially Win 98) just fine. What is not working? Is the client not installing correctly? Please clarify.
DUN is not working proberly.... I have also heard
from a customer, whice created a TAC incident that
the TAC supporter said that Win ME is not working
proberly with client 2.5.2
Under Windows ME I can't get the VPN Client Authentication to get past "Negotiating Security Profiles". It comes back with "Unable to Negotiate IPSec".
This sounds like a configuration problem. Ensure the group name and passwords match between the client and concentrator.
Contact TAC for help with your Win ME install problem with DUN.
I have three Cisco routers (2610 in London, 1720 in Singapore and 1603 in Brazil) that I have been configuring for a small VPN solution using RSA Encryption.
The VPN between the 2610 and the 1603 works perfectly. I am now trying to do the same thing between the 2610 and the 1720. The problem I am having is with the encryption. The IKE completes successfully. IPSEC Security Associations are created successfully. Authentication, Integrity and Encapsulation work perfectly but as soon as I add DES encryption into the Transform Set the data across the link comes to a standstill.
Any help with this would be much appreciated
I would think you could do DES encryption on a low volume of traffic with no problem.
Double-check all of your crypto config for errors.
If you need, post the configs and I can take a look at them.
A possible problem is the throughput capacity of a 2610
with software encryption. A 2600 can attain up to about 1000K
packets per second with DES encryption with a 512 byte packet size.
A solution to this is to fine-tune your access lists to only encrypt the vital traffic you need to protect,
and not encrypt all traffic between the routers. This will expose the unencrypted traffic, which may or may not be a factor in your case.
Another possible solution is to increase the capacity of the 2610 with a
Cisco 2600 series Modular Multiservice router Virtual Private Network Modules
(VPN Module) to optimize the platforms for
virtual private networks (VPNs).
The Cisco 2600 AIM-VPN/BP advanced interface module (AIM) can be added to all current Cisco 2600 models to
provide hardware-based encryption services with up to 6-Mbps triple Data Encryption Standard (3DES) performance.
Hope this helps!!
I recieved the following information from my counterpart in Japan. I am to install a VPN using a Cisco router with them... I would like a router that is compatiable with the following and also allow me to use dialup/remote access into my network through the VPN.
When you will purchase a router, We would recommend the
purchase by a combination of "cisco router + IOS + Feature
Set (manual IPsec(DES56bit))".
It is setting of a command base, and setting of a cisco
router seems to be considerably complecate that it is
an opinion of LAN Technical-center of Fujitsu (cisco connection).
To avoid load during test period, we want to confirm connection
before the test in Japan.
(1) Please confirm the product(cisco router + IOS + Feature Set)
which you can purchase mentioned in above.
Please advise version information & Feature Set.
Connection with "1999.12 cisco4700 ios v 11.3" has confirmed
in Japan.
There seems to be a similar product as equivalent to the cisco 2600.
(2) In Fujitsu office, cisco and safegate(SDK Firewall soft)
environment will be established and confirm connection through test.
(3) We refer to the test result into account and set SDK and INC.
Then proceed to test with Inc.
If you will need our further assistance, please inform us.
I am a rookie but want to set this up correct and I believe that if we both you Cisco routers this will be an extreme advantage. I already have a Cisco 2600 router. I will purchase a new one to hang off a seperate DSL line. Any help you could give me on direction for this would be great. The IPSec is very important..
Here are some suggestions based on your request.
Please resubmit comments if you need further clarification.
MW.
1. Product/Router
I would recommend a Cisco-3660 WAN/Access router based on interface capacity, IPSec throughput, and cost comparable to a 4700:
The 3660 is appropriate for a larger branch office or a smaller central site.
It is recommended for customers desiring a 4700 which is end of life.
It provides great interface and capacity expansion capability.
It allows installation of the wide range of 3600 series WAN and other modules.
CISCO 3661-AC with appropriate WAN interfaces (for example, E1 NM-HDV-1E1-30)
Description: 10/100E Cisco 3660 Series, 6-slot multiservice platform with IP software, 8-MB Flash, 32-MB SDRAM, one AC power
supply, 19" rackmount kit .
Performance: Provides approximately 3.8 Mbps 56-bit DES with a 512 byte input packet
Recommended option for high performance:
AIM-VPN/HP DES/3DES VPN Encryption AIM for 3660-High Performance gives up to 6 MBps 3DES performance
Keep in mind the ADSL WAN (wide-area network) Interface Card for the Cisco 1700, 2600,
and 3600 Series of modular access routers (available on the Cisco 1700 end
of September and on the Cisco 2600 and 3600 in Q1 of 2001)
A lower cost alternative is Cisco-3640, which has less modular expansion capacity.
A 2611 or 2621 may also work as you mentioned, although it is of less capacity than 3640.
The 2600 would be fine for a branch office.
See http://www.cisco.com/warp/partner/synchronicd/cc/pd/rt/3600/prodlit/36kmp_ds.htm
or http://www.cisco.com/warp/public/cc/pd/rt/2600/
for more information.
2. SW Release
You could use Cisco IOS Release 12.1(5)
ENTERPRISE/FW/IDS PLUS
IPSEC 56
Requires 16 MB Flash and 64 MB RAM
Actually, use any feature set meeting your need that includes IPSEC 56 or IPSEC 3DES
See http://www.cisco.com/kobayashi/sw-center/sw-ios.shtml
IPSec is supported in 11.3(T) and later releases.
3. Configuration Steps
IPSec configuration is complicated.
Here is a synopsys of the tasks, steps, and commands:
Task 1-Prepare for IPSec
Step 1-Determine IKE (IKE phase one) policy.
Step 2-Determine IPSec (IKE phase two) policy.
Step 3-Check the current configuration.
show running-configuration
show crypto isakmp policy
show crypto map
Step 4-Ensure the network works without encryption.
ping
Step 5-Ensure access lists are compatible with IPSec.
show access-lists
Task 2-Configure IKE
Step 1-Enable or disable IKE.
crypto isakmp enable
Step 2-Create IKE policies.
Step 3-Configure pre-shared keys.
crypto isakmp key
Step 4-Verify the IKE configuration.
Task 3-Configure IPSec
Step 1-Configure transform set suites.
crypto ipsec transform-set
Step 2-Configure global IPSec SA lifetimes.
crypto ipsec security-association lifetime
Step 3-Create crypto access lists.
access-list
Step 4-Create crypto maps.
crypto map
Step 5-Apply crypto maps to interfaces.
interface serial0
crypto map map_name
Task 4-Test and Verify IPSec
Display your configured IKE policies.
Display your configured transform sets.
show crypto ipsec transform set
Display the current state of your IPSec SAs.
show crypto ipsec sa
Display your configured crypto maps.
show crypto map
Enable debug output for IPSec events.
debug crypto ipsec
Enable debug output for ISAKMP events.
debug crypto isakmp
Key points:
Plan it out, ensure routing works without encryption.
Design the crypto access lists to encrypt desired traffic.
Account for all crypto peers.
Test it on a small network, then scale it up.
See Cisco IOS Docs for more help at following URL or on Cisco Doc CD:
Security Configuration Guide
Security Command Reference
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/secur_c/scprt4/index.htm
Or attend our Security certification courses:
Cisco Secure Virtual Private Network (CSVPN)
http://www.cisco.com/warp/public/10/wwtraining/cust/classes/C-TRN-CSVPN.html
I authored the course.
Hope this covers it.
Sorry for the delayed response.
I need help configuring ipsec on pix
Hi Ali,
Here is my reply, sorry for a late response:
What follows is a summary of the major tasks, steps, and commands for configuring IPSec on PIX.
Also included at the end are references to Cisco Docs and training.
Regards, MW.
PIX Tasks
Step 3-Check current configuration.
write terminal
show isakmp [policy]
show crypto map
Step 4-Ensure the network works.
ping, send interesting traffic unencrypted
show access-lists
isakmp enable
isakmp policy priority
isakmp key keystring
Step 4-Validate the configuration.
Task 3-Configure IPSec Parameters
Step 1-Configure crypto access lists
access-list access-list-number
Step 2-Configure transform set suites
crypto ipsec transform-set transform-set-name
Step 3-Configure global IPSec security association lifetimes
Step 4-Configure crypto maps
crypto map map-name seq-num ipsec-isakmp
Step 5-Apply crypto maps to an interface
crypto map map-name interface interface-name
Step 6-Verify IPSec configuration
Verify general access lists permit IPSec traffic
show access-list
Verify correct IKE configuration
show isakmp
show isakmp policy
Verify crypto access lists and crypto map
show access-list
show crypto map
Verify correct IPSec configuration
show crypto ipsec transform-set
Verify correct global IPSec SA lifetimes
show crypto ipsec security-association lifetime
View current state of IKE and IPSec SAs
show isakmp sa
Clear IKE SA
clear isakmp
Clear IPSec SA
clear crypto ipsec sa
Debug IKE and IPSec
debug crypto isakmp
debug crypto ipsec
Example Debug Result for Successful IPSec SA Setup
return status is IKMP_NO_ERROR
TaskX---Configure CA Support
Step 1-Manage Flash memory usage (optional).
Step 2-Configure the PIX's time and date.
Step 3-Configure the PIX's host name and domain name.
Step 4-Generate RSA key pairs.
Step 5-Declare a CA.
Step 6-Configure CA communication parameters.
Step 7-Authenticate the CA.
Step 8-Request signed certificates.
Step 9-Save the configuration.
Step 10-Verify the CA support configuration.
Step 11-Monitor and maintain CA support (optional).
PIX IPSec commands and procedures are listed in:
IPSec User Guide for the Cisco Secure PIX Firewall Version 5.3
On Cisco doc CD or at:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v53/ipsec/index.htm
Some training resources
PIX VPN is taught in
Cisco Secure Virtual Private Network (CSVPN)-Dedicated IPSEc course on PIX, Cisco IOS, Cisco VPN 3000 series
Cisco Secure PIX Firewall Fundamentals (CSPFF)
http://www.cisco.com/warp/public/10/wwtraining/cust/classes/C-TRN-CSPFF.html
Cisco Secure PIX Firewall Advanced (CSPFA)
http://www.cisco.com/warp/public/10/wwtraining/cust/classes/C-TRN-CSPFA.html
Managing Cisco Network Security (MCNS)
http://www.cisco.com/warp/public/10/wwtraining/cust/classes/C-TRN-MCNS.html
Hope this meets your needs!
MW
I have upgrade our PIX 515 to 5.2(3) and have installed IPSEC 56bit key. I have the VPN clinet version 1.1. How do I configure our PIX 515 to allow VPN clients? Our Customers will be dialing up using a ISP or DSL coming into our network to access resources and mail. I just need a simple config example to get me going..and explain how the VPN works once our User's try to connect..what is taking place on the PIX? Thanks
First I would recommend that you use the VPN 3000 client version 2.5 or higher. It is the preferred VPN client, although the ver 1.1 client works fine.
The 2.5 client is easier to administer as the security policy is controlled by the PIX administrator.
The 2.5 client is part number CVPN3000-CLNT-25=.
I think it provides an unlimited licence.
You may be able to download it over CCO at no cost if you are a registered CCO user.
Configuring the PIX for the VPN 3000 2.5 client is shown below for example:
isakmp client configuration address-pool local dealer outside
isakmp policy 10 authentication pre-share
access-list 80 permit ip host 192.168.P.2 10.0.Q.0 255.255.255.0
ip address outside 192.168.Q.2 255.255.255.0
ip local pool dealer 10.0.P.20-10.0.P.29
(Can also use external DHCP server in PIX 5.2)
nat (inside) 0 access-list 80
aaa-server t+ protocol tacacs+
aaa-server t+ (inside) host 10.0.P.10 tacacskey timeout 5
(you will need a RADIUS or TACACS+ server such as CS ACS)
(Administrator determines IPSec transform, etc):
crypto ipsec transform-set aaades esp-des esp-md5-hmac
crypto dynamic-map dynomap 10 set transform-set aaades
crypto map vpnpeer client configuration address initiate
crypto map vpnpeer 20 ipsec-isakmp dynamic dynomap
crypto map vpnpeer client authentication t+
crypto map vpnpeer interface outside
vpngroup student1 address-pool dealer
vpngroup student1 idle-time 1800
vpngroup student1 password ********
(group name {student1 here} and pw must match that configured on VPN client.)
Additional tasks:
Install and configure VPN client, configure group name and PW to match vpngroup name and pw)
IPsec setup is as follows:
1. User makes connection via ISP, activates VPN client
2. Client connects to PIX via IKE phase 1, negotiates policy, prompts user for auth (username/pw), proxies auth to AAA server, auth OK.
3. IKE Phase 1 negotiation complete, set as per PIX config
4. IKE phase 2 negotiation is made, set as per PIX config
5. Client inside IP address set per vpn pool on PIX.
6. Communications continues.
See IPSec User Guide for the Cisco Secure PIX Firewall Version 5.2, URL:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v52/ipsec/index.htm
OR attend CS VPN class:
MW
I am currently running a PIX 515 w/ VPN. I would like to setup a vpn connection with a client that is utilizing a Cisco VPN concentrator. This client needs acces to our web servers for the purpose of taking a web survey and no access to the remaining internal LAN. What would it take to setup a secure connection between the two sites with minimal access to our internal LAN. Would it be a good idea to setup a DMZ for the webservers that the client needs to access?
I recommend the following setup:
Client
Cisco VPN 3000 Client, ver 2.5x
Concentrator
Cisco VPN 3015-3080 depending on capacity (has 3 interfaces)
Refer to http://www.cisco.com/warp/public/cc/pd/hb/vp3000/prodlit/vpn3k_ds.htm
for help in choosing model.
Security Policy
It seems that you have a trust relationship with this client, so you may not need as strong security, so the recommended simple design should be OK
Toplogy
Simple Design
VPN 3000 Concentrator
Public interface to perimeter router/ISP router
Private interface to inside network
DMZ interface to DMZ where you place webservers
Advanced design
If needed, you could use the PIX and Concentrator together:
PIX providing max security
Place VPN 3K on PIX 3rd interface, aka "VPN 3K on a stick"
Config PIX to acommodate IPSec traffic from outside to dmz interface (static, conduit, or access-list)
Config PIX to route clear traffic from VPN 3K to dmz to inside interface.
Place Web server on inside network.
2nd alternative, more secure: use a total of 4 interfaces:outside, inside, then dmz1 to VPN3K public interface, dmz2 to VPN 3K private interface.
Configure traffic through interfaces: more difficult to config, more secure.
Recommendation: use the simple design in your case!
Configuration for Simple Design
Configure clients to point to concentrator public interface to terminate IPSec
Configure clients with group name and password to match those on Concentrator
Configure concentrator to limit access to DMZ only
Use VPN 3000 concentrator GUI (web browser-based) quick configuration to easily config the setup.
Tune the setup to only permit remote clients to access the DMZ network/webservers using the NETWORK LIST feature:
1. Set up the network list to permit destination to DMZ network only
2. Apply the network list to the group you place users in
Hope it works for you!
I have a Pix 520 with 5.1(1) and want to add ipsec, how do I get the 520 to prompt me for the new activation keys that I have.
jni
You need to re-tftp the file to the pix for the activation key prompt to appear.
Yes, TFTP the file with the copy tftp command.
Reboot the PIX to activate the new image, and you will be prompted to enter the activation key.
I tried to tftp the same file 5.1(1), but did not get prompted for activation keys.
We have a PIX 515 running 4.4(4). We want to connect remote offices, which use DSL, back to our corporate site. Do I need to upgrade our PIX to version 5.1 to allow VPN with IPSEC?
Yes, I would upgrade to PIX 5.2(3).
You could use 5.1(2) if desired.
4.4(4) does not support IPSec.
It sounds like you plan a site-to-site topology,
with the PIX at the head end.
You could have PIX or Cisco IOS at the remote end.
The key is to configure access lists on the PIX and device at the remote end to select the traffic to secure based on IP address, network, protocol, and/or port.
PIX VPN also taught in:
Hope it works fine for you.
Hi, the VPN3000 concentrator is new to me, and I
would just like to ask if it is possible to set
up a GRE-tunnel between an IOS-router and the
concentrator ? for the purpose of running a dynamic
routing protocol(eigrp), and all wrapped up in IPSEC.
70
