11-14-2017 03:25 PM - edited 02-21-2020 06:45 AM
We have ASA with Firepower module managed by virtual FMC. I've noticed on FMC that application of access policy is still running for almost two weeks.
Can you help me on how can I check thru CLI its progress or if there is a way that I can gracefully abort the application process?
Thanks in advance for your inputs! :)
11-15-2017 03:40 AM
When a job shows as still running like this after an extended period it is usually a corrupted database entry. It is generally not recoverable by the customer admin.
Please open a TAC case so that they can look into the system closely and fix the orphaned job without damaging anything else on your system
11-15-2017 04:28 AM
thanks Marvin, so there is no way for the admin to stop manually the process, right?
