03-22-2016 03:26 AM - edited 02-21-2020 10:21 PM
Can someone from Cisco please explain what this image is? And what parts of ASA does include ? Can it do VPN/Anyconnect ?
Is ASA OS getting retired ?
Solved! Go to Solution.
03-23-2016 01:56 AM
03-23-2016 01:02 AM
03-23-2016 01:12 AM
So basically all features of current ASA OS features will get transferred into FTD? I'll stick with ASA OS with FirePOWER combo until this FTD gets all the features.
03-23-2016 01:56 AM
03-23-2016 02:26 AM
One more question. Will any migration tool be provided?
03-23-2016 02:41 AM
http://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/5500X/ftd-55xx-X-qsg.html
Br,
Per Tenggren
03-23-2016 02:43 AM
Already read that. Doesn't mention any migration tool.
03-23-2016 02:49 AM
What do you want to migrate? The classic ASA ACLs can't be migraded to the FTD afaik.
From the release notes:
When you reimage and install Firepower Threat Defense on your 5500-X appliance, all previous files and configurations saved on the ASA will be lost.
03-23-2016 02:52 AM
I don't want to migrate right now, but i have ton of other settings for AnyConnect, VPN and AAA in ASA currently and i was just asking when FTD gets all features of ASA OS if it will be possible to migrate those.
03-23-2016 07:36 AM
FTD doesn't yet support all of those features (read VPN) , so we don't yet know if that's something which will be possible. Once an image supporting anyconnect with full vpn functionality releases , we will know if it can be done.
Right now , all needs to be configured manually.
05-11-2016 12:05 AM
What about FTD 6.0.1 on ASA w/FP, and defining NAT and Routing in FMC and have FTD on ASA w/FP do it ?
There is surely a document or release notes that tells you what each FTD ASA/wFP version can do ?
05-11-2016 12:12 AM
I think yes...
http://www.cisco.com/c/en/us/td/docs/security/firepower/601/relnotes/firepower-system-release-notes-version-601.html#pgfId-433655
01-12-2017 10:09 PM
I have re-image to FTD 6.1.0 on ASA5506. I would like to ask that can I re-image this FTD back to FTD as factory default on FTD.
Thanks.
BR,
Thaung
01-13-2017 03:29 AM
If you re-run the FTD imaging process on an ASA that is already imaged with FTD it will indeed restore it to a new installation state.
Just follow the process described here:
http://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/reimage/asa-ftd-reimage.html#pgfId-129933
03-06-2017 10:12 PM
Hi Marvin,
Good Day!
I have ASA5525-X but I convert it to run the FTD code. May I know if we can do port-channels in the FTD? Currently, I'm checking the config and I don't see any port-channel config in the on-box GUI nor in the CLI.
