Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Highlighted
FirePower Mismatch in ASA HA Pair Problem?
I have noticed this on one of the ASA HA PAIR , FP mismatch.
Active
ASA FirePOWER, 5.3.1-152, Up
Standby
ASA FirePOWER, 5.3.1-155, Up
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: FirePower Mismatch in ASA HA Pair Problem?
Minor version mismatch should not cause a reload. You can see the reload cause(s) with "show failover history" from the ASA cli.
Are you using the Firepower modules? If not, you can just uninstall them. If so, you should really upgrade them - your versions are literally from the initial release of Firepower on ASA time period and there are hundreds of new features and bug fixes since then.
Thanks for your kind reply :)
520
