Firesight to device maximum latency
wanstor
What is the maximum response time permissable between a firepower device and the FSM?  We'd like to have firepower devices managed in other contries from the same FSM.
Thanks in advance
yogdhanu
If there is minimum of 256 KBps of bandwidth between FMC and sensor , that should be enough for normal policy push. Upgrades might take longer if the bandwidth is not enough.
Hope that helps.
yogdhanu
Hope that helps.
Thanks for the prompt response however I'm specifically looking for the round trip delay in terms of 30ms for example.
If the device is roughly 70ms rount trip does this have any adverse effect on anything?
Were you able to get an answer to this?   I have the same design concern, and am worried about latency between a US-based FMC and ASAs in EU and APAC.
Also, are there concerns with the FMC being accessed over a VPN tunnel (tunnel terminated on ASA running FP) ?
Good day,
Does anyone have an answer for this?
